Cracked frame, need stronger shock mounting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazinaire, May 28, 2002.
  1. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    AAARRRGGGHHH!!! This weekend at Pismo, I finally cracked my frame! It was right where the upper rear passenger side shock stud bolts in and it is about 5'' long horizontally. The stud is still in there fine just ever so slightly pointing downwards, but I'd rather not damage the frame any further. How should I go about repairing this? Would simply running a bead on either side be enough? The upper shock mount plate that is attached to the top of the frame on the drivers side rear is also bent slightly downwards. Besides angleing my shocks inwards with a new crossmember, what are some stronger then stock ways to mount my rear shocks while mainting my lower shock mounts? I plan on installing limiting straps soon too.
  2. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    I don't know if the blazer's are the same as the trucks but I had the same problem on my truck. What I did was cleaned up and then welded the cracks up. Then I took some I believe it was 1/2inch threaded rod, and stuck it through the hole in the frame where the shock mounts go and put a nut on it on both sides so it was tight. Then I welded that right to the frame. It seems to have worked real well.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    why retain the stock lower mounts? if you want flex, ditch them. anything would be an upgarde, check out the rear set ups that Missouri Offroad Outfitters has along with the one Howlin' Off Road offers....
    If you want to keep the stock lowers we can work something out on that too
  4. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    The stud is still good and I have extras if it did break, it is just the point where it goes into the frame that is weak. No damage was done to the shocks either, they are just trying to pull the stud through the frame. I will try welding the frame and reinstalling the stud. I am also worried that if I mount limiting straps to the frame, they will try to pull through just like the shock studs. I know that I want one per side, to keep from overextending when articulating, not just when the whole axle droops. So I guess the new question would be how could I mount the limiting straps so that the top mounts won't pull through the frame?
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    interesting
    I would have guessed that frame problem was damaged on compression.
    common problem with K5 frames
