cracked frame?
Discussion in 'The Garage' started by shaun89, Feb 4, 2006.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i know how a frame cracks and stuff, but i tightened all the bolts on my steering box then had a frame turn back and forth, i could see the box move around a realll small amount....i have 38" tires...could the frame just be flexing from the size of the tires or do you think it is cracked?:confused:
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
  3. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    ya i know...i was stupid i only went wheeling once tooo...i didnt know it would happen that fast:(
  4. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Make sure the steering box bolts are not just bottomed out on the steering box threads. Sometimes the bolts can bottom out on the threads before it completly tightens the steering box down to the frame, and cause you to think the steering box is tight, when it is not. Throw couple of flat washers on the bolts to shim them back a little, so they will not bottom out, and see if this works. THEN GET YOURSELF A STEERING BOX BRACE AS SOON AS POSSIBLE. Watch out for the same "bolts bottoming out" thing with a steering box brace as well. The best way to securly bolt a steering box to the frame is to drill out the bolt holes, and run a bolt all the way through it. Then put a nut and washer on it.
  5. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    Ok ill try that, but thanks for putting up with my stupidity and thanks for the info :bow:
