Cracked NP208, have questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DukeBoy88, Mar 14, 2005.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    Hit a rock in the snow with my M1008, denting the front diff cover and causing a 1" crack on the front of my transfer case near the output, kind of where you would expect to see it. The transfer case still functions, It has a steady drip leak, I limped it home and its sitting in my garage. This is my daily driver toy hauler, I usually drive it carefully to keep it dependable. My questions are:
    1. Can I weld the crack shut? even as a temporary fix? or is that to be avoided.
    2. I have a spare NP208 from my '88 GMC K5 that sat behind a TH700R4. what would need to be changed to make this swap in behind the TH400?
    Thanks in advance.
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Would need to swap input shaft/gear
    Gotta take the whole thing apart to do it... but it's not that bad.
    Marv
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just like Marv says , its not really hard . Jaysbeast and I did mine fairly straightforward . Just get an exploded diagram ( I have at home ) and pay close attention . Taking pics helps :D
  4. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I have a couple of spare 208 housings that you can have if you pay for shipping.
  5. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Thanks, I'll keep that in mind if I mess this one up.
