cracked starter bolt hole on 400sb-help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Flipper, Oct 20, 2000.
  1. Flipper
    Flipper Registered Member
    Oct 19, 2000
    38
    West of Mpls. MN
    Last starter change out on the trusty 400 (75 vintage, no emmisions thank u) found outboard hole for starter craked
    up the side in the thread area (verticle in the threads) crap! I've heard of this but thought of urban legend only stories. All that porting and polishing on the heads, all the fun stuff, Edlebrock intake, roller rockers, ARP rod bolts carefully streatched to torque, I'm ready to break down here, really...
    Got stick welder and seen a little cast iron stick rod usage, should I?Then re tap? Or is welder pro really needed here? Cripes, wife will freak when loading this block in the Buick.
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I'm not an expert but here are a couple of ideas.
    1. try an extracter for boken bolts, they are used with a drill, sears will have them, the home depot, etc. use plenty of wd-40 or liquid wrench.
    2. simply drill the bolt out with a size thats a little smaller..........hope this helps.......js
  3. Flipper
    Oct 19, 2000
    38
    West of Mpls. MN
    I wish it were only a bolt, but it's the block "ear" for the starter that's cracked.
    Who let the dogs out!!!!!!
  4. mrivan
    mrivan 1/2 ton status
    Sep 10, 2000
    123
    Coastal Mts. Or.
    your not going to weld that with a stick welder (A block soaks up heat like a giant sponge) ,sounds like a job for a real pro and it will probably have to be out of the truck ,what a bummer. I think you should treat yourself to a nice polished alum.pan while you got it out.
    Mrivan
    Ford people loose their keys down the outhouse.........
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    similar problem happened with a 350 I had. the whole corner came off. had it fixed at a welding shop. He did it with the engine still in truck. towed it to his shop with the starter already out. the engine scattered later and the block still held up. I scraped the block. I'm sure it was unrelated.
    your right. I don't understand the jeep thing!
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Welding Cast iron is pretty finicky. Actually its a PITA! You need to do a fair bit of preheating and ideally it should be prevented from cooling too fast. I had to repair a cracked transfer case adaptor for my NP 205, and after pre-heating, welding and chipping I buried it in a big bucket of sand so it would cool more slowly. It is kinda ugly looking but its strong and does'nt leak.
    Oh yeah I'm sure you already knew but I thought I'd mention it anyways, you also need a special electrode, Ni-rod, for cast iron welding.
    If you trust your welding, weld it up and re-tap the hole, if your unsure of your welding, take it to a shop, that sounds like too good a motor to give up on!
    Rene
  7. Flipper
    Oct 19, 2000
    38
    West of Mpls. MN
    Rusty, thanks for the starter info, feel much better.
  8. Flipper
    Oct 19, 2000
    38
    West of Mpls. MN
    Blazer 73, Thanks for the good ending on starter area breakage, feel much better about welding/repair.
