cracked steering arm???
Discussion in 'The Garage' started by 85 Jimmy, Apr 24, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    ok, i've looked over my truck since this weekend when i bashed my truck really hard and the only thing that seems to be broke is my steering arm...
    it's not really broke but it's got a huge crack in it, i need to replace it but i plan on doing a 6" lift down the road, so can i use a steering arm for the lift or do i need to get a original style one?
    and how long can i drive (no offroading) on it like this?
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    You'll be able to drive until it lets go, could be forever, could be now but assume NOW.
  3. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    so can i use a steering arm from a lift?
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Is your rig stock or lifted?
  5. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    it's lifted, but the PO did 4" blocks all the way around. i plan on a 6" spring lift but don't know when i can get the $
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Lets see.....
    Cracked steering arm
    Death just around the corner.....
    Unless you have a flux capacator like the Delorian i would just park it until you get it road worthy.....Or at least let us all know where you will be driving it so we can be sure to stay away.
  7. reverett
    reverett Registered Member
    Mar 25, 2006
    11
    Seattle, WA
    4" Blocks all around = illegal (at least the fronts) = front axle wrap = probably what cracked your stearing arm = unsafe.
    You gotta have leaf springs up front to be legal and safe. Most lift kits include a steering arm so you got that taken care of. Best advice is to park it and get that kit on there before you drive it again.
    Rob...
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I believe the steering arm they use for a 4" lift and a 6" lift are the same. So go buy a raised steering arm for a 4 or 6" lift and install it. Driving with a cracked steering arm is just asking for HUGE problems.
    With a 6" lift they sometimes compensate for the extra lift with a drop pitman arm.
    Harley
  9. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    You should definitely replace that steering arm and look to get those blocks out from under the front springs ASAP. You can use the same arm for the 4" that you'll end up using for the 6".
  10. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    thanks guy's i'm taking out a loan to build a motor and get TCI tranny, i guess i'll take out a few more $$$ to get the lift
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have a stock steering arm from a 10 bolt you can have for shipping cost.
  12. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    thanks, but i'm jsut going to bite the bullet and get the lift kit, but if that doesn't work out i'll let you know
