crackes flex plate - any ideas ?? -(finally fixed)
Discussion in 'The Garage' started by chasone64, Dec 9, 2005.
  1. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    I have a 350 with a th400 & a 203, and a cracked flex plate...
    I have a tranny jack, but I don't know if I can ballance the tranny & case on it. I was thinking of dropping the case & then sliding the tranny back to get it out, but that's a lot of work.
    Has anyone tried sliding them both back with a jack??
    What about an adapter to hold them both??
    Just looking for ideas...
  2. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I slid them both back.
    It is a pain in the @$$ to lift them back into position if you don't have a second jack.
    After a while I just borrowed the neighbors.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    slid mine both back together. I dropped the cross member with them and used it as the jack point. It was still front heavy but nothing I couldn't handle. Make sure you support the motor.
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Get yourself some long bolts with the same thread and diameter as the bolts that bolt the tranny to the block. Thread one into each side of the tranny, support transmission with a floorjack. Remove crossmember, and shift linkages, unbolt flexplate from torque converter. Slide the transmission back on the jack and the long bolts threaded into the block. At this point you unbolt the flexplate from the crank and replace it. Then push the transmission forward and reatach everything. When I did mine, I didn't even have to remove the drivelines.
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    This will be the best way. Or use your tranny jack some chain and a couple buds to drop the tranny/t-case and re-install. Its a real beatch!!
  6. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    This is a great way to do it. Just run the bolts from your starter into the lower bellhousing holes and slide it back.
  7. chasone64
    Dec 15, 2004
    88
    Oregon
    That's what I was thinking, now just to get some time off from work to do it...:mad:
    Thanks for the info
  8. chasone64
    Dec 15, 2004
    88
    Oregon
    Back on the road...
    Well finally got it done.
    What a PITA, prev owner used four different sized bolts in the tranny crossmember, wrong bolts for the flex plate to torque conv.:mad:
    Took some looking, but my friend had the correct bolts.:D
