cracking a k5 hard top
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bowtie4466, Oct 31, 2002.
  1. bowtie4466
    bowtie4466 Registered Member
    Apr 30, 2000
    13
    Has anyone ever cracked a fiberglass hard top from flexing a lot? I am about to go on a wheeling trip in a couple of weeks and was wondering if i should worry about this. Any info would be appreciated! Thanks. /forums/images/graemlins/k5.gif
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Mine cracked in the rear corners. I have two cracks on the rear corner passenger side, and one crack in the drivers rear side.
    About then the tailgate started to pop-out. My body kept flexing way too much. I put a bar between the upper bed-rails close to the tailgate to keep it together when it flexed.
    Someday I will put in diagonals from the top of the bed rails to the floor.
    Oh yeah, my tailgate cracked in the center too - from flex. I welded it up, and it cracked again! /forums/images/graemlins/angryfire.gif
    Than again, I have a full top blazer.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I had a full top blazer and they had this weekness. Mine actually poped the rear glass because the sides opened up releasing the tail gate which shattered my rear glass.
    I made reinforcement by tying both ends of the sides with an angle iron bolted to one of the bolts of the top at each end. I also had the corners cracked from that.
    I never had any problems after I reinforced it though.
    Now I have a 76 with the half top and as you can see from the pics (click on my sig) it's really abused yet the top is still in good shape except a couple of bolts went through the base of the top because i didn't have the chrome plate on or large washers to ditribute the load.
    If you have the half top I wouldn't worry about it, but if you wnt to you can do the same setup as TopOFF and me, it should be better than nothing.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I have busted my full top on my '74, but never had a problem with my '79. You'll probably be fine.
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Never had any problems w/ my '78 or '80, but my '73 has a 1/2 cab top made from a broken full top and I cracked it going up an RTI ramp.
  6. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    My 74's top is coming apart at the back corners..... /forums/images/graemlins/1zhelp.gif
  7. Grim-Reaper
    7,385
    Atlanta
    That was funny!. I need to send you the picture of that /forums/images/graemlins/smile.gif
    Yep I cracked my 75 at the passenger side rear lower corner. Not bad but it's there. A lot of my flex problems when away when I installed a full cage. The cage did wonders for stiffening up the body.
    Never had a problem with the 79. It's held up just fine.
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I ran the hardtop on my '82 for years with no trouble. It would pop some when I was really twisted up but no cracking.
  9. lt61173
    lt61173 1/2 ton status
    Apr 9, 2002
    105
    Republic, Pa
    My 74's cracked at the top corners of both side in the back also.
  10. transcore1
    transcore1 Registered Member
    Aug 15, 2002
    44
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't know if the pics are online yet or not, but Greg did that this week end. The top actually poped off and out while he was flexing his muscles (rig)
    It's a 72.
    Be carefull, make some braces side to side, and make a full cage to stiffen the body, if you have a full top.
    If you have a half cab, then I guess the only time you will crack it is if you drop it /forums/images/graemlins/thumb.gif
