Cracking Frame? Steering box
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBurban350, Dec 16, 2002.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Has anybody had any problems with the frame cracking at the steering box? If so, were you running a lift w/ large tires? /forums/images/graemlins/burb.gif
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    This is a very common problem on these 4x4 trucks, stock or lifted.
    There are many different aftermarket fixes. A weld-on plate, or my favorite the ORD steering brace with ties the back two bolts of the gear box to the center section.
    http://www.offroaddesign.com/catalog/steeringkit.htm
    BlazerMan
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    The best solution is to run both the weld on plate/repair kit and the ORD steering brace.
    Rene
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you do any work on the frame yourself make sure you stitch weld it if you weld it.
    the idiots that owned the wifes jimmy before i did welded the he!! out of the frame and caused it to crack even worse.
    Grant
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Don't wait to repair it, it will only get worse. When I noticed mine the frame was split all the way up the bottom and the side. I took a piece of 1/2" plate steel and cut it to fit, welded the frame back, bolted the plate in, and drilled a couple of holes thru the frame and plate so I could add some grade 8 bolts. So now I have the 4 bolts that hold the steering box to the frame, 2 3/8 bolts, and a couple of spot welds holding the plate in place. It's one of the few things that I can say I will never have a problem with again /forums/images/graemlins/cool.gif.
