craked frame
Discussion in 'The Garage' started by adamforsythe, Aug 7, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    When I was tearing into my 1985 K5 (pulling tranny/t-case/engine) I noticed that both of the frame rails where cracked right under the tranny cross member.
    When I was yanking the engine, tranny, etc on my 1986 K5 I found the same thing but on one side. Is there something that I can do to keep that cross member from putting stress on my frame?
    Adam
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have broken my frame in pretty much all of the common spots, but never by the tranny x-member. I would love to see a couple of pics of where it is cracked? Do you have spacers in there to lower the Tcase? Are all of the bolts tight? How are your tranny mount bushings and motor mounts?
  3. no1uknow
    no1uknow 1/2 ton status
    Nov 10, 2004
    145
    Southern Cali
    Good question, my frame is cracked in the same place...................
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    when I bought the frame thats under mine now it was cracked on both sides where the crossmember bolts up, the PO had wheeled it pretty hard, I just stop drilled the cracks, then clamped the cracks back together and stick welded them and ground the welds flush. No more problem! :D
  5. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Just curious, but was the crossmember flat against the frame, or were there spacers between them ???
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I don't have a camara right now. I do have spacers on the crossmember.
    When I yaked the engine and tranny all of the mounts where good.
    Adam
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    It has spacers.
    Adam
  8. MarcS
    Oct 4, 2002
    515
    NJ
    Were they between the frame and the crossmember dropping it down, or just on the bolts under the crossmember ???
    I'm just thinking because the stock spacers are small in diameter and may be pushing in the frame when between it and the crossmember. Thinking larger ones to prevent cracking.
    Thanks for the info.
  9. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I believe they where under the crossmember.
    Adam
  10. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Is your crossmember one of those that bolts to upper and lower section of the C-Channel frame, or one of the ones I've seen a few of that only bolts onto the lower c-channel section?
