Crane Cam
Discussion in 'Engine | Tranny | T-case' started by roadnotca, Oct 2, 2005.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    #113801, $50, New-in-Box (NIB) :deal:
  2. sweetk30
    Nov 1, 2004
    25,551
    544
    horseheads , ny 14845
    what does it fit???????????
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Part Number: 113801 Grind Number: H-278-2 (REPLACES HMV-278-2)
    Engine Identification:
    Start Yr. End Yr. Make Cyl Description
    1957 1987 CHEVROLET 8 GOOD IDLE, DAILY PERFORMANCE USAGE, MILD BRACKET RACING, 3000-3400 CRUISE RPM, 9.5 TO 10.75 COMPRESSION RATIO ADVISED. BASIC RPM 2500-5500
    Engine Size Configuration
    262-400 C.I. V
    Valve Setting: Intake .000 Exhaust .000 HOT
    Lift: Intake @Cam 3114 @Valve 467 All Lifts are based
    on zero lash and theoretical rocker arm ratios.
    Exhaust @ Cam 3294 @Valve 494
    Rocker Arm Ratio 1.5
    Cam Timing: TAPPET @.004
    Lift: Opens Closes ADV Duration
    Intake 26 BTDC 72 ABDC 278 °
    Exhaust 80 BBDC 30 ATDC 290 °
    Spring Requirements: Triple Dual Outer Inner
    Part Number 99848
    Loads Closed 114 LBS @ 1.700 or 1 45/64
    Open 324 LBS @ 1.230
    Recommended RPM range with matching components
    Minimum RPM 2200
    Maximum RPM 6200
    Valve Float 6800
    Cam Timing: TAPPET @.050
    Lift: Opens Closes Max Lift Duration
    Intake 2 BTDC 40 ABDC 109 222 °
    Exhaust 56 BBDC (2) BTDC 119 234 °
    Remarks:
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    cybrfire answered for me. In short, it fits your SBC, but not good for anything except maybe mud. Don't buy unless it is exactly what you need, or you know where to resell for $$. I bought it when I was in a car mode. :doah:
