crank pulley
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JTB, Jun 3, 2001.
  1. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    I was installing my crank pulley when I noticed four drilled out sections on the back of it. I know this is for balance, but is it to balance the pulley itself or the pulley with the crank? I bought my blazer without a motor but the guy gave me all the accesories and I'm not sure if the pulley was balanced specifically for the motor he had in it before I bought it. It is much heavier then the other crank pulley I have. That leads me to another thought. The other pulley is larger. (in diameter) Does this have a positive or negative effect? I don't want to ruin my rebuilt motor because a pulley is not lined up correctly with the crank and is out of balance. Thanks for the help!
    Jeff
  2. K5krazy
    K5krazy Registered Member
    Aug 22, 2000
    13
    Petaluma, CA
    Pulleys are balanced to themselves. I just rebuilt my motor and the balancer, pulleys and the torque plate were balanced to themselves. Only the rotating assembly was balanced together.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The pullies are ballanced to themselves unless it is a 400 that has an externally ballanced crank.
    '71 Blazer CST with alot of rust
  4. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    How would I be able to tell if it was an externally balanced 400 pulley? I don't know what was in it before I bought it.
    Jeff
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I think the 400 are 8" across were the internally balanced 350 is only 6" across.But don't quote me.
    <font color=green>BobK<font color=green>
    <A target="_blank" HREF=http://www.zing.com/picture/p8947726813026de684f60e0bd6f3fbfe/fe8f5839.jpg>http://www.zing.com/picture/p8947726813026de684f60e0bd6f3fbfe/fe8f5839.jpg</A>
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Are we talking about the pulleys or the harmonic damper? The damper is drilled for balance. My original 350 damper was 8" OD. My FluiDampr is about 7-1/4" OD. I believe the way to tell a 400 damper from a 350 damper is to look for a large raised balance pad on the ID of the damper hub (I don't have a 400 damper, but that's what I've seen on other makes that were externally balanced).
  7. fatdog
    fatdog Registered Member
    Jun 1, 2001
    59
    Soda Springs Idaho
    All of the dampers on my 400's are factory GM and they have what looks like a notch or grooved area cut out around part of the outside edge of the damper. Not sure about aftermarket 400 dampers, I've never run one.
    '65 Turbo Corsa
    '69 Elcamino
    '71 Chev 4x4 Short Step
    '71 GMC 4x4 Long Fleet
    '72 Chev 4x4 K5
