Crank Pulley
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by MuddyMudSkipper, Mar 11, 2002.
  1. MuddyMudSkipper
    MuddyMudSkipper Registered Member
    Mar 7, 2002
    49
    CA
    I was looking at my motor as it was running and I noticed that the crank pulley was slightly off center. I loosened the bolts and reinstalled it but it is still a little off. Could this cause major internal problems or should I not worry about it? The bolt holes are slightly larger than the bolts so it is really tough to get it lined up perfect.
    Jeff
  2. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Muddy, The crank pulley typically has a ridge in back around the large center hole that fits into the harmonic balancer hole to keep it centered. I had purchased an aftermarket alum pulley that wobbled, and it seemed to be off center. I exchanged for a new one and all is perfect now. Good luck. JT
