Crank trigger ignitions - Good or bad?
Discussion in 'The Garage' started by PJTPW, Jul 21, 2005.
  1. PJTPW
    PJTPW 1/2 ton status
    Jan 14, 2003
    226
    Moab, Utah
    I'm considering running a crank trigger ignition to get a super low profile distributor.
    Thoughts on running this set up? Good, bad?
    Any durability issues or anything else to look out for on a dedicated wheeler.
    Thanks,
    Ryan
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Accuracy of one is a big plus, however I doubt the reluctor wheel will be too happy getting all muddy. I know on the LS based motors they have theirs inside the block, so there is no issue, aftermarket Gen I crank triggers mount to the balancer as far as I know.
  3. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    There not designed for ORV's, drag race only...
    the magnetic p/u and reluctor wheel are very susceptible to debri and do not fit well with a rocky, dirty, dusty, wet and nasty environment.
  4. PJTPW
    Jan 14, 2003
    226
    Moab, Utah
    What about a flying magnet crank trigger like this from MSD?
    http://www.msdignition.com/mag_1.htm
    Seems more tolerant of debris. Mud is really not a concern, there's not much here and I generally avoid it now.
    Ryan
  5. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    that's youre basic crank trigger, carry a spare p/u coil to get ya home when it leaves ya stranded on the trail.
    These people make crank triggers as well, but not one for a (censored).
    however you may be able to adapt the MSD crank trigger with the electramotive coil packs and eliminate the distributor altogether.
    http://www.electromotive-inc.com/index.html
    BTW, that's a nice ride ya got there.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    See thats the only reason I'd convert to crank trigger, and I still wouldn't do it on a trail rig. I really want to build a high revving Gen I small block for my dad's Firebird, and I'd like to run crank trigger and distributorless.
  7. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I hear ya...i love screamers also, that's why i put 6.000" rods in my 383 stroker.
  8. PJTPW
    Jan 14, 2003
    226
    Moab, Utah
    Dodge=censored? :crazy:
    I've seen the light and am building a GM based buggy this time. :D
    Thanks for all the input. Maybe I should just stick with a regular distributor.
    Ryan
  9. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Overkill....
    Crank triggers are the ultimate ignition systems because the plug is fired in relation to crankshaft position as compared to the gear on the back of the cam (except ford which has the dist. in the front).
    Conventional distributors must deal with the harmonics that are transmitted thru the crank gear, up the chain and then all the way to the back of cam where it is gear driven again.
    Spark scatter and inaccurate timing curves is a common occurence and disadvantage of the HEI chevy ignition.
    1 disadvantage to the crank fired ignition is locked-out timing but on a race car it does not matter when those motors rarely see rpm's below 3,000....
    timing computers are available today that allow a street driven vehicle to use a locked-out dist. and/or a crank fired ignition but it's overkill for all but the most radical street/strip machines.
    The low rpm's that a trail rig or rock crawler encounters does not require the accuracy and (headaches) of a CFI...........IMHO :bow:
