crank turning
Discussion in '1982-Present GM Diesel' started by odee1, Jul 27, 2004.
  1. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    I'm gathering parts to rebuilt a 6.2 or 6.5 for my dually that I tow with. I was wanting to know what is the prefered way on the crankshaft? I have heard to turn it down others have said not to even think about turning it. So which way is right?
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I seem to recall reading somewhere that the 6.2/6.5 cranks can't be turned because they have nitrided journals. They can be lightly polished, but not turned down.
    I'm not positive on that, though.
  3. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,036
    1,093
    Dallas
    Jarhead is right.
    The 6.2/6.5 cranks are made of nodular iron, and they are heat treated to have a fine pearlitic matrix for excellent ductility. The journals are then nitrided for good wear properties. This combination gives a hard enough surface to resist wear, but a ductile enough core to resist the shock loads of 21.3:1 diesel combustion.
    The nitride layer is only a few thousands thick, and any grinding will remove this wear resistant layer is short order.
    Polishing is okay; grinding is bad. /forums/images/graemlins/smile.gif
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Jarhead is right.
    What he said! /forums/images/graemlins/thumb.gif
    Casey
  5. odee1
    Feb 27, 2004
    50
    So I guess the answer is not to run one that has been turned. I have seen alot of bearings lately on ebay for a crank that has been turned on mains and rods. I thought it might be a good way to save a few dollars on a rebuild.
  6. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Most gas engine crank journals can be turned. The 6.2 crank is made differently though. Wouldn't surprise me if other diesel cranks are the same way.
