Cranking Compression vs. Octane
Discussion in 'The Garage' started by bigburban383, May 10, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Apparently my engine knocks a lot, even though I don't hear it, I know this because the sensor tells me. I checked the cranking compression on a few cylinders and I am getting 150 psi. Would 93 octane be good enough for pressures like that, I have no clue of the compression ratio. I have dished pistons and unshrouded 305 heads.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    how much of a dish? Unshrouded 305 heads are probably like 59/60ccs. With flattops that would be about guessing at 10.5:1 compression. You are probably in the mid or upper 9s, I'd say try a little bit of 89, then try a little bit of 93, whichever gives better results(power,knocking,etc.) go with that. If it runs good on 89 there is no reason to run 93.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    How dished are the pistons? Stock 83 305 heads on a 305 produced 9.2:1 compression, hence the need for ESC. Bigger piston diameter on your engine will lower the compression a bit. /forums/images/graemlins/k5.gif
  4. johnc
    johnc Registered Member
    May 6, 2004
    68
    O.C., CA.
    http://www.carcraft.com/techarticles/982/
    I hope this can help... /forums/images/graemlins/dunno.gif Generaly 10.0 to 1 will work on premium with cast iron heads without pinging /forums/images/graemlins/waytogo.gif
  5. johnc
    May 6, 2004
    68
    O.C., CA.
    [/ QUOTE ] actualy a bigger piston diameter will raise your compression due to the greater volume being compressed /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Then the compression ratios of all those smog 350's in the 70's with 76cc heads would of been really high, right?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No. Larger chamber heads will reduce compression ratio. 76 cc heads are huge.
  8. johnc
    May 6, 2004
    68
    O.C., CA.
    [/ QUOTE ] /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gifExactly /forums/images/graemlins/peace.gif
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    After a re-read of that article it makes sense to me but its funny. Overboring an engine RAISES compression by ADDING volume, however using larger chamber in the heads ADDS volume and LOWERS compression. That is the part I forgot about. /forums/images/graemlins/k5.gif
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I try not to question, a 400 can have the same compression with 76cc heads that a 350 has with 64s, I just think of that and well thats that.
  11. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    These are specs from the 383 "Street Friendly" kit in my engine:
    9.0:1 with 64cc heads
    8.5:1 with 76cc heads
  12. johnc
    May 6, 2004
    68
    O.C., CA.
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif you got it ! Sounds wierd though at first, I'll give you that one! /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you are pushing probably 9.5:1+, like I said 89 might work but I'd say much more towards 93. any pictures of your chambers? I remember them a while back but forget now.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Actually he's closer to 10:1 or right at it. I would be willing to say that with 305 heads, 10:1 CR, and any kind of torquey cam, that engine is going to knock like a Diesel under load no matter what pump gas you choose.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm asking about his heads cause, if he has a nice polished chamber it would be a help. I said a little less than 10:1 cause he elarged the chamber by unshrouding the valves. You are right though, it will be tough to get around.
  16. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Since your engine and my engine are the same CID, I opened up the compression ratio calculator that I wrote in Excel and checked a few things.
    With a 4.06 bore, 3.75 stroke, 12cc dish piston, 72cc head etc etc my comp ratio is 9.463:1. I changed nothing but the head cc...which I changed to 58cc to reflect the 305 head......and the comp ratio jumped to 10.9:1! /forums/images/graemlins/eek.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/yikes.gif
    You probably did not square deck the block for good quench which will lower the comp ratio, but make the engine more prone to detonation.
    I would guess you are between 10-10.5:1 which is WAY too much for a street motor in a heavy Burb. Loose the 305 heads and find a good set of 350 heads with either 64 or 76cc's. You'll be much happier with the engine. /forums/images/graemlins/waytogo.gif
  17. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Those pistons must have a big dish in them (like 20+cc's) to get the compression #'s you posted in a 383!
    Tearing into the motor might not be something you want to do...but putting in a larger cam will help bleed off some pressure and you might be able to get away with the cheeper gas. Cam's don't cost a hole lot so you shouldn't have that long to break even...on the plus side you will have some more HP which is always fun /forums/images/graemlins/waytogo.gif
  19. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Oh My Got, 10.9:1, I suppose that is the problem. I'm an idiot! Thank you Chevy for ESC and Knock Sensors /forums/images/graemlins/bow.gif
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Decking the block into a good quench zone does the exact opposite. It will INCREASE compression ratio, and make the engine LESS prone to detonation.
    Even with perfect quench distance in a 383 with a torquey cam and 305 heads and 10:1 static CR, it's going to be VERY knock prone.
