cranking torsion bars
Discussion in 'The Garage' started by 91Chevy2500, Sep 30, 2002.
  1. 91Chevy2500
    91Chevy2500 Newbie
    Sep 30, 2002
    Signal Mnt. Tennessee
    Ok i am in need of info on how to crank my torsion bars on my truck so i don't have to pay a butt load of money to achive a small amount of lift and still be able to run 35s.
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Umm, you won't be cranking your bars enough to clear 35's with no lift. The most you should ever crank is about 1". After that you start getting CV wear due to the extreme angles. If you want to crank, theres a bolt on each side of the t-bar crossmember. Tighten the bolt to raise the truck, loosen to lower.
  3. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok, so essentially you wish to KILL / MURDER your geometry and tires and alignment to achieve 1-1/2 inches? youll never even know it was done, dont or youll spend those tons of dollars on tires and preperation H /forums/images/icons/wink.gif /forums/images/icons/grin.gif
  4. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    I could not agree more with the above posts, all you'll end up doing is wearing suspension and tires.Your suspension will be riding on the torsion bars alone and the truck will handle like a wet noodle on the road.I spend almost every day at work trying to talk someone out of doing this, we have done it for one customer in the past and within a week he was back in the shop begging to have the front end lowered again.
  5. 91Chevy2500
    91Chevy2500 Newbie
    Sep 30, 2002
    Well as of right now i have a 3in body lift and in the process of triming the finders so that i will only have to crank them at the most an inch.
