Crankshaft pulley removal question
Discussion in 'The Garage' started by rafterman191, Mar 15, 2007.
  1. rafterman191
    rafterman191 Registered Member
    Aug 28, 2006
    54
    Indiana
    To remove the crankshaft pulley on my SBC 305, there are 3 bolts in a triangular pattern and 1 in the center. I was thinking the one in the center would not have to be removed, but now I am thinking I must be wrong. What is the best way to keep the crank from turning while removing that middle bolt? I have the other 3 bolts off right now, nowhere to hold to secure the crank while I loosen the middle one. My crank pulley split clean through on me, never heard of that happening before.
  2. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    You can use a tool on the flyweel...or just take the bolt out and move the engine back to where it was with a flywheel tool.... i have used a pair of vice grips to turn the motor....
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    I'm inclined to use the impact on the center one, but I'll presume you don't have one handy.
    Also helps if your motor is seizes so the crank can't turn :doah:
    In your case, try something like this:
    http://www.amazon.com/Vise-Grip-27-Locking-Chain-Clamp/dp/B00004SBCB
    Harbor Freight sells a cheaper one -- that was just the first Google hit I found.
    Put the bike chain around the pulley, and you'll get a LOT of leverage. Put a cheater pipe pn the pliers and you'll have plenty.
    Don't ask me why I know this :whistle:
    -- A
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Put the belt back on if you can, it usually will hold it enough to pull the bolt.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Put a long breaker bar on it, and turn the engine with the starter...:rolleyes:
    sheesh, what's wrong with you guys, the easiest way to do something, and you want to tell him to get the proper tools for the job, especially something as simple as removing a balancer, basic mechanical stuff here.
    :D :haha: :doah: :wink1: :p:
  6. rafterman191
    Aug 28, 2006
    54
    Indiana
    That wasn't as bad as I was anticipating. Used a strap wrench on the pulley and came right off.
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
