Crankshaft
Discussion in 'The Garage' started by danny7139, Feb 10, 2006.
  1. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Should a new engine have a crankshaft that you can't turn by hand? If so what did I do wrong I torqed them to the right spec and everything.
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    with the pistons and rods in or with just the crank in?
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    As has been asked, if it's just the crank it should turn smoothly with a light drag. With the rods and pistons etc on there then you will need a barring socket on the end to turn it. there will be quite a bit of resistance to get it moving and then will need a firm turn to keep it moving.
    If it is just the crank you'd better take the caps off and make sure the shells are seated properly. Before you do that though, give the crank a firm-ish thump with a soft hammer to seat the end thrust bearing.
