Crap 5.7?
Discussion in 'The Garage' started by PsychoticDeadGuy, Jun 12, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Well, on my way to go wheeling yesterday, my motor started missing and running really rich, and on startup, it surges a few time then get to a missing 700ish RPMs. What could cause this? Bad plugs, wires, cap and rotor? What about o2 sensor for the running rich?
  2. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    vacuum leak.
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    Well, I just replaced the o2, plugs, wires, cap, rotor, and the air filter. It still surges but not as bad. It also spits out black smoke, what does black mean?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    black smoke is running rich.
    did you change the ignition module?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    it would run lean if there were a vacuum leak...
    can you give a little background on your rig? headers with a standard one wire O2? tbi? anything changed recently?
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    my rig ran pefectly fine, it just happened. the plugs and o2 sensor were charcoal black, not oily. the motor is all stock, TBI. could it be the timing?
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Check your coolant temp sensor, MAP sensor, and 02 sensor -- In that order.
    They are the three components that control your fuel the most :)
  8. PsychoticDeadGuy
    Jan 8, 2005
    753
    I already changed the o2 sensor. How does the MAP and temp sensor affect the motor to make it sound like its missing and blowing out black smoke?
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if its running as rich as it needs to be to blow black smoke its going to misfire on fuel.
    MAP and ECT are 2 of the 3 primary inputs in a TBI system. The computer uses their input A LOT to determine how much fuel to put it. The MAP lets it know how much fuel is coming in, and the ECT lets it know how cold the engine is.
  10. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Is it not throwing any codes???
  11. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    My guess is either the vacuum line came off the MAP sensor or is plugged or the MAP sensor is just plain bad. I had my rig run the same way once when the vacuum line came off the MAP sensor.
