crap! crack in frame...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Dec 28, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I am putting my ORD Brace on right now...and guess what I find? there is a hairline crack in my frame parallel to the pitman arm when pointing staright ahead. It isn't on the middle part of the frame, just the bottom one, and it doesn't go all the way through. I'll have to go to a friend's house and weld it up today I guess. Doesn't seem major enough to need a frame repair kit...any opinions?
    90K5
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Make sure you go over the whole area with a "fine tooth comb"!! I had a small hairline crack, had it welded, and then had a big one crack through (and this was AFTER I had the ORD brace on for a couple of years)...now I have the brace as well as the weld in repair kit...but if you only find that one small crack, and weld it up good, you should be ok, but keep an eye on that area!
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I'd get the weld in kit regardless of how small that crack is now. Get it done once and forget about it (hopefully anyway).
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Well, I went to a local muffler shop, and got the crack welded up, and have the brace installed. It made a pretty good difference in how the steering feels, and ithe front end feels a lot tighter, especially over bumps. I'm kinda concerned about the welding though...not knowing much about welding, but wouldn't you use differnt wire for welding up mufflers than frames? If so, I'll probably get it redone somewhere else, and get the frame repair kit...anyone?
    90K5
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Same welding process...no need to worry. Most muffler guys are actually very good welders.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Allright thanks
    90K5
