Crap, good welder needed!
Discussion in 'Pacific Region' started by renny, Nov 27, 2004.
  1. renny
    renny Registered Member
    Apr 20, 2004
    30
    Salem, Oregon
    Well, the outer starter bolt hole in my small block 400 that I just finally finished putting in my '85 K5 has cracked right through the edge of the block. Does anyone know of a good welder in the Salem Area that can weld cast iron while the engine is in the vehicle. Is that even possible? Or am I totally screwed?
    Thanks in advance for any replies
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I dont think that is going to be possible in the truck. To weld cast iron you need to put the piece in an oven and warm it up to a certain temp before welding (plus need plenty of room around the piece for a tig welding setup preferably).
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    It can be welded with special nickel cast iron rod..
    the area has to be very clean and pre heating with a torch is recommended... its iffy doing it in the truck... kennys right the best way is out
    I have done farm equipment in the field with good luck.... but they arent running down the road either,,,
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Here's a few within 20 miles of Salem.
    Clicky
    You can just about bet that the shop will want the engine removed.
    Yer prolly lookin at around $150
    Good luck I feel your pain.. /forums/images/graemlins/tongue.gif
