Crap, it's broke again!!
Discussion in 'Pacific Region' started by seattlek5, Jan 2, 2005.
  1. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    Broke it again! Got to get it fixed by Memorial Day....
    Can some one post these pics in the thread, and let me know how to do it. Thanks.
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Nice work man
    cough cough 4speed.........:whistle:
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yup, another good reason to put in a 4spd and cut the top completely off!!! I still have that 32 spline SM465 if you need one... :whistle: :whistle:
    Good carnage!
  4. seattlek5
    Feb 23, 2001
    311
    I thought you got rid of that. I'm keeping the auto, just looking for another case to build. I'm also going to fab up some torque rods to run from the bellhousing to the doubler. As for the top, I'll be cutting that off very soon:hack:
  5. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    do u have 2 crossmembers?....and do you know why it broke?...i often worry about my own...
  6. seattlek5
    Feb 23, 2001
    311
    I have a crossmember that supports all the mounts (4) on the t-cases. I'm running Energy Suspension motor mounts and all four t-case mounts. I think it was a combination of having the frame a bit twisted in the rocks and applying a lot of torque to the trans:dunno: A torque rod like the stock one may help, so that is the plan on the next one.
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I'd say the frame was twisted up in the rocks but your crossmembers are too rigid and didnt let the tcase's rotate up enough when the motor got rotated by the twising of the frame. Weakest link is what broke. I'm not completely sure the torque rods would be enough. I'd be more inclined to re-design the crossmember and add the torque rods.
  8. white-rhyno
    Jan 27, 2002
    942
    I got worn out motor mounts and only one crossmemeber. I have flogged on mine hard in double down. Never had a problem. huh.
  9. seattlek5
    Feb 23, 2001
    311
    maybe I need to go down to pull-a-part and find some worn-out motor and t-case mounts:haha:
  10. white-rhyno
    Jan 27, 2002
    942
    hmmmm, better grab the the 4sp while your at it :waytogo:
    really though, i hope you get it fixed for naches. DO you need a case? bet i could get one pretty easy, shouldnt matter if it was two wheel drive right?
  11. seattlek5
    Feb 23, 2001
    311
    Found one for $150, it does have to be a 4WD or "K-case" (thicker.) I plan on having it done soon, along with the 400SB and a cage to add some rigidity to the frame and protection for the family. I'll be doing some build up type threads in Feb. or early March depending on the sidework.
  12. kennyw
    Jun 9, 2002
    13,223
    94
    Even adding the cage might help stiffen up the frame enough to prevent this from happening again :thumb:
  13. seattlek5
    Feb 23, 2001
    311
    ...3 hours later, here's what I have.
  14. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    ... so is this when the SB400 goes in...?:grin:
  15. leadfoot067
    May 14, 2001
    1,563
    whatcha doin with that 327?
  16. seattlek5
    Feb 23, 2001
    311
    mothballs...it's got a special spot under my bench all picked out:grin:
  17. leadfoot067
    May 14, 2001
    1,563
