Crappy flex pics
Discussion in 'The Garage' started by clarkjw24, Sep 24, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Man my stiff arse springs suck. I can't wait to do the 52 and 64 swap. Here are some crappy flex pics so I can compare the before and after the swap.
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Stupid ammounts of flex is not the be-all and end-all. And that isnt exactly bad flex, either.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i like it! is that a 20 degree ramp :wink1: ?
    ryan
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    actually I think it is. But the side I use the ground slants down so that prob give a few more degrees.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    what year 63's are you gonna use?
    88-98
    or
    99- up
    ryan
  6. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    that isnt that bad at all actually- but as metioned FLEX isnt everything. if you want a good laugh check out how my 12"ers do. Lata Ryan
  7. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    That is crappy? :dunno:
    I guess mine is borderline sucky. :(
    Stock length EZRides front and rear.
  8. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    if you guys are bad then I'm just down right horrible. My argument is this is still my DD and it's got stock length 6in lift springs and the sway bar still on. But after seeing these results yeaterday it's just bad:haha::haha:
  9. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i was just wondering because i plan on doing the 63" swap in my k5, will you be doing a write up? i would really like to check it out...
  10. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    New wheels looking good John. When's that 60 going to find its new home?
  11. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'm using a set from an 89, atleast thats what was wrote on them :o
    They were freebies, just had to buy some new bushings. I've got to move the gas tank first and build a new rear bumper before the spring swap.
  12. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thats the same thing I'm running right now. Stock length 6" springs front and rear. I could live with the back but the front is stupid stiff. Does anyone know if some of its because I've got stock steering instead of crossover?
  13. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    are you running a sway bar?
  14. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    No I dropped the sway bar awhile back. It helped, along with longer brake lines and ford towers but the front springs are still really stiff.
  15. captaininsano
    May 4, 2004
    233
    Bay Area, CA
    Stock length 6" lift springs won't flex for **** IMO. Reminds me of those days when my K5 flexed (rather didn't flex) like that. 4" lift springs seem to be the max if you want good flex from leaves.
