Crate 350 "deiseling" idleing high
Discussion in 'The Garage' started by mendo, Dec 12, 2006.
  1. mendo
    mendo Registered Member
    Oct 22, 2006
    37
    Santa Barbara, CA
    Lately my crate 350 in my k20 has been idling at around 1500rpms, loosing alot of power at full throttle and when I turn it off it deisels for about 10 seconds before it turns off. I thought it was the timing and adjusted it but it still is doing the same thing, so i guessing its the carburator. Does it need a rebuild or could it just be out of adjustment, any tips on adjusting it to run right? thanks
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    vacuum leaks.
  3. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    The high idle may well be causing the dieseling.
    Yes, check for vacuum leaks; also check the idle adjustment ... maybe your fast idle is stuck?
    -- A
  4. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ya you could have a vacuum leak somewhere under your carb. or your linkage may kinda hang up. retart your timin just a hair and see what happens. for now just shut it off in gear and it wont diesel.
  5. mendo
    Oct 22, 2006
    37
    Santa Barbara, CA
    When I shut it off in gear it still diesels
  6. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    as above; idle that thing down to about 600 in gear (auto) then see how it idles (smooth?) and it should stop when told to. Start there and post up with the results.
  7. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    choke out of adjustment
