*crate engine* oil leak help i can't find it-
Discussion in 'The Garage' started by boggerless, Sep 6, 2003.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    *crate engine* oil leak help i can\'t find it-
    a month ago i was burning old gas out of J.R.-my truck-and it fouled the plugs. so i put fresh gas in a can and sucked it through the pick up hose,well most of the gas that didn't burn went in the oil pan. i changed the oil and started it back up,every thing was fine except oil was spraying on the header and starter.only when i reved it up though.i thought it was the oil pan gasket but i spent an hour looking today and there is a mist on the side of the head and valve cover,real light like it's been there.the bottom of the oil pan is a little wet so is the bottem of the bell housing.when i started it today it didn't spray, /forums/images/graemlins/confused.gifi don't get it. anyone have an idea where to look??? /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Re: *crate engine* oil leak help i can\'t find it-
    Sounds hard to find, the only advice i can offer is if it is spraying out under pressure, it shouldnt be the pan or a valve cover, since the oil pretty much just flings around these areas. Check any oil pressure switches you have. Or clean the motor very well, get a light ready, and start it up and hope it does it so you can see it well.
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    look on the opposite side of the dipstick, where it would be on the other side, there is supposed to be a plug there the might have not been put in fully or at all.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Get a dye shot and a uv light and it'll be easy to find.
  5. boggerless
    May 26, 2003
    22,728
    96
    thanks guys, i'll look for that plug.the thing that makes me the crazyest is that it seem's to have stoped. but if idon't find out what it is you know it will start at the worst time. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    maybe it ran out of oil /forums/images/graemlins/rotfl.gif
  7. boggerless
    May 26, 2003
    22,728
    96
    that might be my answer, drain the oil and it will quit. damn why didn't i think of that.like i told the newbie only the best advice /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  8. boggerless
    May 26, 2003
    22,728
    96
    BOWTIERED you are the man.the plug was missing right were you said it was.i owe you one big time brother. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    /forums/images/graemlins/thumb.gif
    Glad i could help!
  10. boggerless
    May 26, 2003
    22,728
    96
    man i was literally seconds away from droping the pan.thanks again /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
