crate motor or parts store rebuilt motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Taz, Mar 28, 2001.
  1. Taz
    Taz Registered Member
    Dec 31, 2000
    77
    SE Wisconsin
    My motor seized last night. the local parts store want $800 for a rebuilt motor (15 month 15,000 mi warentee) and the cheapest crate motor I could find was $2200. has anybody had any problems with a rebuilt?
    This is for a '83 Chevy 350
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    It's prolly more of a decision of which warenty you want. Just look at the specs and see if the rebuilt has been bored over to such an ungodly amount that you can't rebuild it cause then you'll loose your core if you have your truck long enough. Why did it seize? Did you forget to check yer erl (that's oil for you city folk)?
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    I and everyone i know have always used parts store motors. Never had any problem with them, except having to go back after the break in period and retighten tthe rockers. What seized on your engine? The crank? How many miles? Take it apart and find out. If your top end is still good, i would just buy a short block. Much cheaper that way. But a little (lot) more work.
    One From None
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yeah like Mudd'n said... check the specs and hp. A plainjane no bells and whistle crate goes in the $1300 range. It also depends what parts store.... Not sure what is in your area, but I know here CSK(aka checker, schmuck or whatever they are called...) aren't worth a dime. Generally I would stick with NAPA although they tend to be a bit more expensive, but they are top notch. You could also get one shipped from nationwide... I have used them and they are excellent... shortblock 350's for about 600 and long blocks for about 800... warranty too.
    <A target="_blank" HREF=http://www.nationwide-engines.com>http://www.nationwide-engines.com</A>
    1987 Chevy K5 Blazer- 350 TBI
  5. Taz
    Dec 31, 2000
    77
    SE Wisconsin
    the oil pressure guage said 30 psi when I started it up, if there was no oil in it I was pushing air or the sending unit was shot
    I drove about 1 1/2 miles and smoke/oil shot behind me. when I got it home I saw a long crack in the bottom of the pan, so either I threw a rod or hit something??
    thanks
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sounds kinda like you might have lost a wristpin (busted out of the piston). If so, that motor is toast on the bottom end. Depending on what happened with that piston, one of the heads may also be toast (or at least need new valves and guides).
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  7. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    You could also get an Edelbrock Crate Engine [​IMG]
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have known a few people who bought Auto Zone and Advanced Auto Parts engines with good luck!
    Also liek the others said, you can get a GM re-man. I have seen 205hp 350's for around $1100 here ..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    GM's Targetmaster 350's aren't re-man's. They're brand new engines from top to bottom. They aren't high-performance, just stock 350's. But they go for around $1,300. Pretty cheap for a brand new 350.
  10. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Napa's selling a 383 stroker 400hp for around 2,000. WOW!!!
    Talk about a brute!!!
  11. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    The standard GM 350 crate also puts out 249 Horses, which really isn't that bad if you think about it. It's not some super engine but thats more horses than what came stock in these blazers.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  12. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Back in 96 I bought a 350 from the dealer I don't remember how much but it was up there $1,800. The plus was that they deliver it to your house. Also it's all new,and painted up!
    You can check out my rig right here <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  13. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Problem with rebuilds is that when they put it back together the only replace the parts that don't spec. right. A crate motor is all new. I figure if I am going to do it, I want to do it right. Even if it is a couple more dollars.
  14. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Hey mudd'n... Napa has that? They have the specs and parts listed for that online somewhere...?
  15. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Hey Taz!? What exafctly are you looking for w/ a motor. Cheapest good running motor you can find? A rebuilt or one with a warranty... Also what kinda performance? Stock... a bit more... or something in the nice 300 or 350 range to get the trucking going? BTW... chances are w/ a crate motor you are gonna end up changing the cam anyways to one for more torque then hp.
  16. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Here ya go Cap:
    Four star long block 383 stroker
    Part # is CP383LB
    373hp 420 ft lbs torque
    9.5:1 compression
    pink stripe cam
    stock 350 heads
    It runs on pumpgas
    Nick said to go to your local Napa and ask if they sell Four star motors and give them that part number. When my motor goes out I'm putting one of those in there. [​IMG]. He said he couldn't give a price cause his store gets some sorta discount.
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    True, but it's hardly what I would call "high performance". [​IMG] The next step up gets you to around 330 HP. Quite a difference from stock. [​IMG]
  18. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i put an autozone motor in one of my company trucks, an 82 ford 302, 2 1/2 years ago, and the thing ran great until one of my guys ran it hot, and blew a head gasket. and after a head and valve job and some new gaskets it is running great again. when i had it apart i decided to order some fun parts from summit, and installed a higher torque cam, and a 2 roller timing chain. that was a first for me, and it really was not hard. just took some time. i think about 12 hours total
    chris
  19. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I'll have to ask our rep Tim about it... then he can give me the hook up... whatever the store gets it for... I get it for [​IMG]. Sounds interesting... not sure how great of a deal it is w/ stock heads when a Speed-0-motive 383 shortblock goes for 1200... Thanks
  20. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    Hey dudes, I'm new here. This is a topic of interest for me also. What are your opinions on the 383 that Chevy offers. Saw it on the Jim Pace site. And they got a complete 350/330 for $3100. But does that got the torque to move our rigs?
    1972 K5
