crate motors
Discussion in 'The Garage' started by johnnysjimmy, Apr 10, 2002.
  1. johnnysjimmy
    johnnysjimmy Registered Member
    Apr 23, 2001
    47
    Has anyone bought a crate motor from GM lately? I am looking into buying the 250 horse motor for my 73'. I am too busy to build one right now! I am looking into building a small block 400
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i just bought mine...picking it up tomorrow from the terminal. will let you know how it goes.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    World Products (the people that make DART) have a 415 cid SBC that is suposta be pretty stout. It's alittle pricey, but well worth the extra $$$ If I was going to buy a crate motor, that'd be the one. You can order it with the cam of your choice.
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I bought mine about a year ago...No problems other then valve cover leaks...Dan
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    In the past year my dad and my brother have gotten 350 crate motors from GM. One was a ZZ4, and the other was a 225 horse I think. They both have been great motors so far.
  6. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    If your looking for something to put in until you build the motor you want, I have a completly rebuilt and machined 307. It is complete from pan to manifold. Is just like buying a crate motor. I am wanting around $750.00. This has 0 miles on it.
    Just thought I would offer.
  7. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    My experience with crate motor:
    I bought a medium duty 350smallblock goodwrench motor in Dec. 00'. In June of 00' I spun two main bearings and broke the crankshaft!
    Luckily, It was under warranty. I had a dealership replace and reinstall the motor for free! I've had good luck so far. Hopefully, this doesn't happen again. I'm thinking 502 next time. He he.
    Juan
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was in your boat with my first crate too. My dad bought the 250hp crate from GM, and with about 15K on the motor the oil seals on the drives side rear two pistons went. I was in Northern AZ when this happened, and it was 300 miles back to Phoenix. I replaced the spark plugs in the two bad cylinders (completely fouled) and then started home. It made it home (barely) and GM replaced the motor for free.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    P.S. I got the 300hp crate to replace the stock replacement crate, and it has worked flawlessly for 35K+.
  10. high&liftedup
    high&liftedup Registered Member
    Nov 14, 2001
    64
    CA
    I recently put in a 250 hp crate in my 76K5.... We put it a comp cam (x-treme), new Q-Jet (750cfm), All MSD ignition, headers, Flows, K&N.....(added ~+40 hp) I have ~3000 miles and ran it recently up in the snow/mud in Sonora with some good revs on the engine when I got stuck.... Runs very well, with great low end & torque/throttle reponse.............. No problems so far..Its a good engine for the $$$$ Its got my recommendation!
  11. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I've bought two new 350 crate motors from Sallee Chevrolet. One was the 350/300hp crate and used it about 12k before swapping to a 383 and then to a 427. The other was a 350 heavy duty for my father-in-law's mini-motorhome. It ran about 20k before exploding outside Kingman, Arizona last week. Turns out the crank broke and at least 1 rod went south. Still in Kingman awaiting replacement at the Chevy dealer there. Supposed to be warrantee, hope so. Before that happened, thought it was the way to go, not sure now.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The "WORLD PRODUCTS" Motown 415 has a 2 year / 24,000 mile warrentie.
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    How much does the Motown 415 run, and what are its power numbers? What RPM do the power numbers come at? Thanks
    Harley
  14. johnnysjimmy
    Apr 23, 2001
    47
    Thanks for all the help guys! Hopefully I will not run into the bad luck some of the motors have had
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I didn't see the more engine info link when I looked earlier. Sorry. Heck, if a 415 SBC short block is $5K and a 632 BBC shortblock is $6K I think the extra 200 cubes might be the way to go. /forums/images/icons/smile.gif If I was going to spend that much on a motor i would by myself a Beck Racing Engine. The offroad 383 with 400hp and 450 ft/lb for $5-6K. That is for the complete motor too.
  17. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The local dealer for "WORLD PRODUCTS" here in Rapid City, SD wants just over 7 grand for a turn-key Motown 415.
