crazy head/tail lights!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Neil, Jan 14, 2002.
  1. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    My '78 K5 has some serious light problems.. 1. apply brake when not running and headlights come on, no rear brake lights come on..2. when turn signal is levered in postiion, emergency flashers come on. 3. no brake lights, just rear running lights and headlights when light switch is pulled out, along with running lights, are the rear white reverse lights. Somehow my brake and headlights are reversed I know. Where do I start!!!! It is like someone has played an evil trick on my K5's lights !!
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Start with a new Painless wiring harness. That should take care of your troubles.
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  3. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    Did you get it this way, or did it just start. If it just started what were you doing before.
  4. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I think you need an Exorcist. [​IMG]
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
