crazy idea
Discussion in '1936-Present Suburban' started by pilgrim, Jul 3, 2002.
  1. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    Does your gas tank get in your way? Well mine does, so i'am thinking on ripping it out and getting (i know there somewhat costly) a www.auxtank.com 70 gallon wedge to fit behind the front bench seat. this would be easy for me since i took out the middle seats anyways. I'd mount it VERY well inside a cage and tied to the frame. Than weld to two side doors shut, and cut and weld in a fuel door on one side. That would give you 30 more gallons of range and move the weight to the center of the truck. Also you'd have a nice departure angle. What do you think?
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    sounds awesome for a trail rig then you could bob the rear end. /forums/images/icons/smile.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif
  3. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    I AGREE BOBBING THE REAR WOULD BE NICE GIVE IT THAT TAHUE LOOK. JUST WATCH THE GAS FUMES. I HAD A TRUCK WITH A GAS TANK BEHIND THE SEAT INSIDE THE CAB AND EVERY TIME I WENT AROUND THE CORNER WITH A FULL TANK I SMELT THE GAS. /forums/images/icons/smirk.gif
  4. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I'm dying to do a trail rig Sub. I wouldn't mind saving my current Sub for towing and family trips.
  5. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    I thought about `avalanching' my K20, but don't have the heart to hack the sheetmetal off it like that...
    -Rich
  6. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    sounds like a good idea...
    just be very conservative with the mounting, dont want the tank to explode if you ever get hit on the side...
    use to have a 74 f-250 highboy, cool truck, but man did that gas tank behind the rear seat scare me, i just didnt like the sound of the gas sloshing around behind me, and it always had a hint of gas in the air....
  7. pilgrim
    Sep 10, 2001
    247
    new hampshire
    so when you say be "conservative" in mounting a tank behind the seat. do you mean soft mount it well inside a cage , so that if hit or in a roll over the tank would have some freedom to move and not just split open... or would you hard mount it inside a cage firmly tied to the frame and body... i'am leaning towards a softer mounting and also might use that race fuel foam , they use it in race cars to prevent the gas from dispursing all around in the event of a tank split, also helps with sloshing. does anyone know the legal (probably varies state to state) height for a gas filler door????
