crazy wiring problem....
Discussion in 'The Garage' started by 1983k5, Oct 31, 2004.
  1. 1983k5
    1983k5 Registered Member
    Oct 31, 2004
    8
    Mountain Home AFB Idaho
    Hi all, first post here, I'm just hopeing someone has an idea. 1983 K% Blazer, just got it for 1500, runs great, all the lights work, even the power rear window works! The problem i have is anytime i move the defog/heat lever from off to anything, it kills the engine. If I'm quick enough in putting it back to off, it will start runnin again......Very strange. I've looked at the fuse box, but there are MANY wires going to it. I've already removed 3 or 4 wires that didnt go anywhere, just capped off at the other end. Anyone have any ideas, other that rewiring it?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Are you sure its wiring? On some rigs that were factory equipped with a/c, the heater controls are off vacuum. There is a port off the intake going to a vacuum canister somewhere near the heater box in the engine compartment then runs thru the firewall into the cab under the dash to the controls. When you turn the controls ON, it might be causing enough of a vacuum leak to kill the motor.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Vacuum is probably the most likely. It's possible that it is creating a really high load and robbing voltage from your ignition. It would pretty much have to be a short, which should just blow a fuse, unless someone bypassed it. I'd say just find someone with a multimeter and some troubleshooting skills. But that's all kinda far-fetched.
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Good chance this may be your problem.
  5. 1983k5
    Oct 31, 2004
    8
    hmmmmm vacuum huh? Thats VERY possible, it did used to have AC, however, it was all ripped out, and all the vacuum lines going to and from a lot of things are capped....I do have a friend with a multimeter, maby i'll bribe him to help me out..Thanks all
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Just because the a/c was ripped out doesn't mean a thing, the vacuum still runs the heater part of the system. The called these Four-Season systems. The only electric runs to the fan speed switch under the dash(and the stuff on the box in the engine compartment). The COLD - HOT and the heater/defrost/vent/etc are all run off vacuum.
  7. 1983k5
    Oct 31, 2004
    8
    ok, so theoretically, its just a vacuum hose not connected or plugged, right? Well, i tried something different today, i started it with the knob in def, then heat, it worked every time, until i changed it, then it died...still sound like a vacuum prob? I get the dang chiltons this week, i'm just wantin to get this beast road worthy lol Thanks for all the input so far tho. You all are sum smart peeps /forums/images/graemlins/eek.gif
