creaks and groans
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Jan 15, 2001.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I was just poking thru some photos on guys sites and the readers rides and came up with a question. for you guys (Steve, Depdog, Stephen etc.) with the really flexy rigs, how much does the truck protest noise wise when you flex it or ramp it? I know when I try stuff like that, the roof kinks, the springs creak, the tires rub (soon fixed :)) and the thing basically tells me to stop hurting it. I was just curious if yours make the same noises mine does, or is mine really falling apart? Just trying to get an idea of what might lie ahead for me.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i know my pic isnt flexy but when i flex i have never had the roof make any noise as far as the springs you can put teflon in-between the leaf springs to stop the noise and make sure everything else has lots of grease that is saposed to have grease anyway lol some creaking and groaning is normal though
    s.smith 77blazer lookin 4 mud
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Mine doesn't creak or groan too much. About the only noise I get is the floor on the drivers side of the truck 'pops'. I guess I got a little over-exhuberant with the welder there and now it oil-cans. Time to break out the hammer [​IMG]
    Rene
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Hey, my floor does the same thing tRusty.
    90K5
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Same here and mine's almost stock. All it has is new front wheel wells, springs, and 31" tires.
    June 2001 - The Texas Sawz All masacre begins. Be afraid rust, be very afraid. [​IMG]
  6. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    My roof kinks when i have it all flexed up too. My blazer basically does everything your's does except rub the tires now.
    <A target="_blank" HREF=http://k5junkie.coloradok5.com/>http://k5junkie.coloradok5.com/</A>
  7. Grim-Reaper
    7,385
    Atlanta
    My wifes 79 has a very interesting bongo sound that hits once when it flexes and gives a return when it unflexes. Haven't figured out where that one comes from but it sounds like a basket ball hitting the truck. I think it's the inner side wall. Gate makes lots of noise and the top creaks on it also.
    The 75 is a vertible coruse of creaks and groans :) when the top is on it makes tons of noise at the windsheild header. Fenders really protest when they hit the body. The rest of the tub is pretty vocal. I haven't really wheeled it since the cage went in. not sure if I will have more or less noise haha.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  8. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    Sounds like my rig is one of the more vocal ones...Hmmmm. My roof pops if i hit a rut right leaving the drive way!!. When I'm actually on the trail going over whoopty doos....oh man....you'd swear it was the end of the world!....The roof pops, the gate shifts back and forth and up and down, The top shifts(for a while i'd actually hear fiberglass on fiberglass rubbage...but that's because my tops cracked). I can feel the floor boards and my seat shifting, the pedals shifting, occassional fan shroud rubbage.....and of couse the good old tire in the front fenders grindage. I wouldn't worry about your rig Thumper......but now that i think about it maybe i should be worrying about mine!!!........nah!
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  9. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I remember when I used to wheel my rig (before I noticed that my body was falling apart.. and when it wasn't winter), my passangers side quater used to sound like someone was hitting it with a baseball bat. I guess my frame flexes a bit or it's the soft stock springs. All I would hear is "WOMP, BOMP." I think my body lift also helps with the flex of the tub along with the absence of the topper.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    It's all fun 'n games, till someone gets stuck.
  10. Thumper
    1,582
    Alberta Canada
    Hey Sarah, thru the summer, my roof became so bad that it would pop and kink just over the speed bumps at McDonalds. I had a magnet cell antenna on it and it would really make it pop lots. I fixed most of the problem by poking a hole in the headliner and injecting some of theat expanding foam insulation. It cured most of it except for when I really bend things up. If yours bugs you, you can give that a shot. Mine was driving me nuts!
    Mike
    85 Fullsize Jimmy
  11. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    a little trick i've used for years to curb those various K5 noises seems to work quite well. the first step is making sure everything that needs to be is lubed up nice, and the noise isn't a cry in pain but just one of "those noises." the second step is to put in your favorite tape or cd and turn it up! the noise goes right away! :-) this is my favorite fix for those nuts that rattle around in the body b/c i only use half the bolts for the topper.....
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  12. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    My top pops on the street all the time. When wheeling, you can feel the tub flex by resting you knee aganst the door. The outer sheet metal popped all the spot welds that hold it to the back of the door post. I welded it solid, it tore again. The b-pillars are torn most of the way around. When I put the hard top on for the winter, I have to get up on top and jump on it for a while to eliminate the gap. My tailpan ripped in half. My buddy's girlfriend went wheeling with me in the Dodge, and said it just wasn't the same without all the noises. I've noticed that ever since the sawzall and grinder hit the fenders, I don't even notice the new dents. In the summer, I unbutton the soft top along the tailgate when wheeling for fear of tearing the snaps out of the vinyl. If it bothers you, I agree with the "turn it up" analysis. Me, I kind of like it.
    Pete.
    p.s. The following is a list of things that do not squeak, groan, rattle, pop, bang, etc. on my truck.
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
