Creeking noise in Front Dana 44
Discussion in 'The Garage' started by toy4x4runner, Apr 21, 2005.
  1. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    WHen I turn the wheel back and forth, mainly when the truck is not moving, I get a creeking noise fron the right front. I'm not sure where it's coming from. I lifted the front up and checked the wheel bearings... no play, and they spin great. and the hubs are in the FREE position. Any ideas?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Could just be some movement in the front springs that is causing the creeking noise... :dunno: Hard to tell without being there.
  3. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    what exactly do you mean? the leaf is binding? or the leaf bushings need some greasing?
  4. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    could be bushings, or dry leaves without the teflon pads?
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Either. Like Heavy Metal said, it could be dry bushings... Or the leaves could be moving slightly...
    It really could be a number of things! Loose frame rivots, loose steering box, cracked frame, loose fender..... Etc...... Could be the tiniest thing or the biggest. I'd say it it drives fine and nothing is loose or broken(check the frame at all crossmembers and at the steering box)... I wouldn't worry much about it unless it is super loud... Old vehicles can make some really strange noises! :)
  6. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    I have brand new leafs and shackles. No frame cracks, no lose p/s pump, new tie rod ends... everything is fresh. I guess I'll use some WD-40 and try to spray different areas and if it goes away I know what's doing it. thanks for the advice. At first I was wondering if something was majorly wrong, but it drive fine, and i've jaked up the front end multiple times for bearing checks and everything.
  7. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Mine did that and it was the bumper bolts. Crank em down...
  8. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    I have a custom front bumper on, that's not the creaking.
