crew cab info ?
Discussion in 'The Garage' started by TWISTEDJACK, Mar 13, 2006.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I went and looked at a 84' crew cab 2wd single rear wheel this weekend it said it was a 3/4 ton I thought that all of the crewcabs after 77 were rated as 1 tons. It this right or did someone just change the badges on the side.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  3. dremu
    Feb 27, 2000
    15,969
    462
    East of San Francisco
    Well, ratings are funny things.
    I have a '74 "C20" crewcab ... however, it has the thicker frame and narrow rear spring spacing characteristic of a 1-ton. It also has the same front and rear springs as a 1-ton single-cab.
    To get the 1-ton in a crew cab you had to go to the rear spring packs with the overloads on top.
    Anyway, while it's nominally a 3/4, it's a stout truck, and can be easily upgraded.
    -- A
  4. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Any idea what axle ratio it should have it has a 350 with a 4 speed.
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    3.21, 3.42, 3.73, 4.10, or 4.56 :D Did I miss any stock 14bFF ratios? (no semi-float in a crewcab ;) )
    Check the glovebox decal for "Gxx" or "Hxx" codes. That will indicate the axle ratio.
    3.73 or 4.10 are most common.
    Yep. 1-ton frame, with 3/4-ton springs & brakes. Basically a 'de-rated' 1-ton.
  6. dremu
    Feb 27, 2000
    15,969
    462
    Well, mine has the same brakes and springs as a 1-ton single cab. Odd, since it's a 8600 GVWR, but I think that was GM playing games with the DOT or CAFE or whatever even back then. A precursor to the "2500HD"'s you see now.:doah:
    -- A
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Did your's have hydraboost brakes ?
    Tom
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hydroboost has nothing to do with it, even some cars had hydroboost
    Gm did play funny with the GVRW requirements, especially with the 1/2 tons before 1980
    they were getting away with making heavy half tons and didnt have to emissions them as much as a regular 1/2 ton
    crew cab 20 series was always around in the second gen years, common,
    and in the first gen years 68-72 were the C20 longhorns and nine foot steps, no 67 longhorns made, late 68 was the beginning of them,
    they were built on the C30 chassis, just like the second gen c20 crews were
    same deal, just different gen
  9. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Hydraboost has a lot to do with it . I know of no C/K/R/V/ 30/3500 truck chassis that was built after 1973 that did not come with a hydraboost set up .
    For the most part H/B set ups that came on cars and lighter duty P/U's were diesel equiped and it was a vacum related need.
    I asked DREMU the question because I am curious if his C-20 Crew Cab came with a standard vacum brake booster like other C-20 CC's that I have seen.
    Hydraboost was not just a random option !
    Tom
  10. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
  11. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    not every single 30 series has hydro, theres lots of 1 tons with vacuum power brakes,
    hydro was a brake option, didnt come with all drivetrain combos and such
    i have seen a few c30s with vacuum brakes, they are around
    like my 78 c30 i had and uhm many others,
    just because youve never seen it doesnt mean theyre out there,
    theyre quite common :D
    saying that all 1 tons were hydro is like saying that all 3/4 ton were FF axle and 8 lug
    you gotta remember, GM was odd, espcially with their gross vehicle ratings
  13. u2slow
    May 9, 2001
    2,217
    BC Canada
    My Dad's 79 C20 crew has a vacuum booster, and JB7 brakes. 2-pin calipers, and 13x2.5" drums. 8200# GVWR camper special.
    Some of the earlier (or possibly low GVW?) 1-ton SRW stdcab trucks had the JB7 brakes also... I haven't seen one, but seems to be a few people that claim they have them. :crazy:
    The '83 C30 SRW stdcab pickup I wrecked out had JB8 brakes (D60 style calipers, 13x3.5" drums).
  14. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Didn't mean to say that it was never made but I have seen a fair amount of these trucks in my life and have never run across one not equiped. As far as your comment that they are "very common" I doubt that - it seems that the norm is H/B and the exception is a low GVW 1-ton as u2slow just said.
    Anyway back to my original question to DREMU did your C-20 Crew Cab hace H/B ?
    Tom
  15. dremu
    Feb 27, 2000
    15,969
    462
    Nope, vacuum, JB7, I do believe, biggest non-Bendix calipers up front and 13x2.5" drums in the back.
    -- A
