Crew cab on a long bed chassis
Discussion in 'The Garage' started by whtsnk, Nov 4, 2006.
  1. whtsnk
    whtsnk Registered Member
    Oct 11, 2006
    5
    amarillo, TX.
    Ive got a crew cab that I want to put on a shorter chassis. Will this cab clear the tires on a long bed chassis or should a suburban chassis be used? On that note is the suburban chassis any longer than the long bed chassis? Any wheelbase information would be greatly appreciated.
  2. whtsnk
    Oct 11, 2006
    5
    amarillo, TX.
    No one has any wheelbase info??????? WTF?????
  3. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    wow, no one answered in an hour on a saturday night. I know for sure theres been a number of CC body on other frame threads lately, I've been reading them. Try looking.
    C'mon... 1 hour of waiting? have some patience.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Suburban wheelbase is 129.5". Longbed std cab is 131.5".
    The Burb frame is likely easier to use. It stays low and flat for most of the span between the axles, unlike the pickup where it angles back up aft of the footwells.
  5. whtsnk
    Oct 11, 2006
    5
    amarillo, TX.
    Thank you U2 that was exactly what I was looking for, someone that already knows the info that I need in order to save time.
  6. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    IIRC it's been done, and depending on the tire size, required some hacking on the back of the crew cab.
    Now, a Burb frame has the shorter wheelbase, as noted ... but is about 6" LONGER overall ... the Burbs have this heinous overhang on the body, more so than a pickup or Blazer.
    And breathe already! :rolleyes:
    -- A
  7. whtsnk
    Oct 11, 2006
    5
    amarillo, TX.
    Thanks for the info Dremu!
  8. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    your best bet is a suburban frame unless you want a 4" hoemade bodylift, or shortening your stock crewcab frame.
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Here's mine on a shortbox frame:
    I have an extended wheelbase by using 52" front, reversed 56" rear springs. This adds ~3" to the front and ~4" to the back. The #'s jive with my measured wheelbase of 124" considering a stock shortbox wheelbase is 117"
    I had to notch the cab corners for tire clearance, and will need to finish them for looks now. As it sits, I don't drag the corner on the tire.... but then again, I havn't twisted it up really hard yet either.
  10. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    looking at your pics a crew cab should go on a 'burb frame and allow you to mount a swb bed....albeit you may have to shorten the frame alittle tho. that would be neat a 4 dr swb...have people scatching their heads thinking.."wtf?"
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    If you do the math, a Suburban is about 20" short on wheelbase to make a crewcab shortbox. Pushing the Burb's rear axle back - you'd have to account for fuel tank clearance also.
    Now f you used a stepside box.... you could slide the fenders around a little. ;)
  12. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    hey i didn't think about a stepside, you could bob it even, either end once you located your fenders. that would look sharp! if done correctly!
  13. k204dr
    Aug 27, 2004
    463
    TN
    if you just want a factory shortbed, move the spring perches forward, and chop off the extra frame, slap on the bed and you're done. thats the simplest way.
