crew cab on burban Frame ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jesterdzs, Apr 7, 2006.
  1. jesterdzs
    jesterdzs Registered Member
    Jul 7, 2005
    56
    Silverspring , Maryland
    Im considering puttting a 85 Up crew cab on my 91 3/4 ton 4x burban with a short flat bed like the ones all pro builds for toys
    would the body mounts line up on the cab ??? Does the frame have the right curves ??? I Planed on moving the axel back about 4 inches to compensate for the lack of room wher the wheel wells were ? :doah:
    Any help would be greatly appreciated.
  2. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    The front mount will work as is, you will have to install the rear cab mounting cross member on the burb frame and then bolt it down
  3. BURB-STYLE
    BURB-STYLE Registered Member
    Apr 29, 2005
    33
    UTAH
    It might line up. just wanted to chime in cause im going the other way like a 98 crew body on to an 83 burb frame and none of mine will line up worth a d#$% so?? Good luck though mines a slow progression kinda deal so maybe when i get somewhere we should make a post for us crewy supporters.
  4. snoman87
    Aug 25, 2004
    88
    Edmonton, Canada
    Now that a whole lot of work ... I hope you are boxing the 83' frame before putting the 98 cab on ... otherwise that would be a down grade in terms of frame strenght, at least from what I hear
  5. jesterdzs
    Jul 7, 2005
    56
    thankns for the info guys as of right noy i just ordered a DIY4x B52 front end kit and a rear shackle flip kit, im still lookin for a good donor cab
  6. BURB-STYLE
    Apr 29, 2005
    33
    UTAH
    ya thats the thing i bought just the cab for 400 and had a partially busted $200 suburban so i know frame strength will be less but it'll be re-inforced and boxed. plus i sold bunches of crap of the burb so im ahead like 25-40 right now. just need some steel tube and plate so i can start butchering! mostly i just wanted to cut up my suburban cause it pissed me off by rolling over in moab last year.
