Crew Cabs..........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SprinklerGuy, Dec 14, 2002.
  1. SprinklerGuy
    SprinklerGuy Registered Member
    Aug 20, 2002
    17
    Woodland Park, Colorado
    Does anyone here know when the first crews were built and what configurations? (i.e. Dually only) I have been looking to get out of my new truck for awhile now, since I bought the 87 burb actually. Now I need a truck and always wanted a 4x4 crew cab, not dually, perhaps short bed? 1 ton maybe! What are my odds? Thanks!
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    1 ton 4x4 crew cab chevy's started in 77. The 2wd crew cab started in 73 IIRC.
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    There's an old 2wd near my house that looks like it has a 73 or 74 grill.
  4. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I had a '73 3/4 ton 2wd Crew Cab and a '77 1-ton 4x4 Crew Cab.
    The 2wd had a 350 and a TH350. I believe it was one of the first model Crew Cabs.
    The 4x4 had a 454 with a TH400 and part-time 203 T-case. It was the first year of the 4x4. Based on the original equipment sticker, it originally had a SB400 and came as a full-time 4x4. I'm not sure when they started putting the 205's in...I know they did by '80.
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    All 77-91 4x4 crewcabs are 1-tons. All are longbox too. Could be had in SRW or DRW in all years. There are older ones, but were aftermarket conversions for logging, railway, and other utility companies.
    I found my 'custom' shortbox version at a logging company auction.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    There are 3/4 ton crew cabs also. Both in 2 and 4wd versions.
    I thought I was looking at a K30 crew cab once while on vacation in Pagosa Springs a few years back, and realized when I got up closer that it was actually a 3/4 ton. And yes, it was a K20, 4x4!!! Had the 10 bolt front, but it was also running a 14FF instead of a SF. Year was in the early to mid 80's.
    There are literally hundreds of 2wd crew cabs in 3/4 ton version, too.
  7. SprinklerGuy
    Aug 20, 2002
    17
    Great! I hope to find a "custom" short box too! But a long box will do as well. Thanks Again!
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    I know of the 3/4-ton crewcabs... but a 4x4?!
    All crewcabs do use a 1-ton frame however - ran into this when sizing up a 14FF for a regular 3/4-ton. 40.5" perch spacing /forums/images/graemlins/smirk.gif
