CREWCAB LONGBED TO SHORT
Discussion in 'The Garage' started by edlavarreda, May 13, 2004.
  1. edlavarreda
    edlavarreda Registered Member
    Nov 26, 2002
    56
    ANY BODY DONE THIS CONVERSION? PICS, HOW TO, WHERE TO CUT INFO WILL BE APRECIATED THANKS /forums/images/graemlins/1zhelp.gif
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    what year id it and why do you want to do it?KEEP THE BEAST LLOOONNNGG. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Crewcab short boxes look SWEET!
  4. boggerless
    May 26, 2003
    22,728
    96
    good enough for me. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. edlavarreda
    Nov 26, 2002
    56
    its an 88 4x4 and have not seen a short bed. did they come with short boxes from the factory? thanks
  6. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    No the factory never built them like that.
    There have been pics of one floating around, I think it was off ebay but it did look really nice.
    Not sure what all you'll get into, but the big part would seem to be shortening the frame and the rest should basically be cake after that.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Mine's spliced just back of the cab where the frame is still straight. It was done by the previous owner - a logging company. Looks simple enough... a buttweld with a 1/4" plate on the outside. Between me and the loggers, its had planty of abuse /forums/images/graemlins/grin.gif
    Also, you'll have to install shortbox saddle tanks or a rear tank.
  8. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    [​IMG] I like this one /forums/images/graemlins/thumb.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    that one is sweet!!
    I bet it's a burb frame.
  10. edlavarreda
    Nov 26, 2002
    56
    that one is nice but the bed is a little too short
  11. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    From what I know the best way to reconect the frame is to have the cuts at a .45 basicly the two halves would be like so // then C channel would be used both inside and outside of the frame to make a rigid connection. Similer to how big rig frames are done.
    I also have a crew cab /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  12. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    I believe you would be correct if you're talking about any solid axle dually crew, but I have seen short box srw crews and IFS crew cab short box duallies in the local papers a couple of times now (next time I see a srw crew shorty I'll be sure to go take pictures).
  13. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
  14. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    that one is sweet!!
    Haha, look at your reply in the linked thread /forums/images/graemlins/thumb.gif
  15. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    That truck looks awsome! Do you have any info on this? It looks like a long bed standard cab frame with a crewcab and the front part of the bed shorten..
  16. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Been thinking about this for sometime now as well. The best way I can think of would be to have a short bed frame and crew frame. Cut the crew behind the cab and the SWB frame behind the cab in the same spot. Graft them together and short bed bad a$$ frame is done! /forums/images/graemlins/thumb.gif
    As far as cutting is concerned only way to correctly do it would be to make your cuts in a step formation. Cut down about half the width forward then down the rest. It would make fitting way easier. Straight would be the key to a successful project /forums/images/graemlins/rotfl.gif
  17. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    freame grafting is a engineered science...
    do it right the first time
    below is a reprint from truck and trailer body
    Tapering, Staggering Essential in Frame Splicing
    Apr 1, 2001 12:00 PM
    By Rick Weber
    AT one point during his “Truck Frame Overview For Body Mounting” session, Dick Toner asked for a show of hands. Which frame splice is the strongest: Straight butt joint? Staggered butt joint? Or tapered butt joint?
    When the votes were in, he let everyone in on a secret: There is no correct answer. They're all the same.
    He said if the frame is not properly reinforced, it doesn't matter which type of splice is used because the joint on the bottom of the frame will fail from fatigue.
    “The bottom rail is in tension,” said Toner, who gives one-day seminars on frames for the NTEA. “It's being pulled apart. The weld we put on the bottom rail is going to fail first. That's why it doesn't matter what kind of butt joint you put in.”
    He said the general rule is that reinforcements should taper a minimum of two times the frame height — which fits into Volvo's recommendation of 20-30 degrees, 20 being 2.7 times the frame height and 30 being 1.7 times the frame height. So for a 9" frame, you go 18" each way and taper from there.
    “Stiff to flexible is bad,” he said. “You want to spread the stress out as much as you can. Any kind of tapering you can put on is good. Sometimes you have to take off crossmembers and shorten them. Sometimes you get away without it.”
    The Seven Commandments
    His frame-splicing commandments:
    Don't go from stiff to flexible. Taper and stagger reinforcements. “If you're in a situation where you're putting an inside reinforcement on and an outside reinforcement on, stop them in different places. Taper, taper, taper. Stagger, stagger, stagger.”
    Stay out of high-moment areas or extend reinforcement to a lower-moment area. “That's when you're working on a straight truck and you know you're going to have to do something behind the cab. Get as far up under the cab as you can. It's amazing how frame moments drop off when you get under the cab.”
    Match steels for yield strength as closely as possible.
    Extend reinforcements a minimum of twice the frame height past the splice before beginning the taper.
    The strength of a frame rail is in the flanges. “I can't repeat that enough times.”
    More steel is stronger than less steel. “If there's a question, increase the gauge. Increase something. When you're putting a reinforcement on a truck, the difference between, say, 1/4" steel and 5/16" steel weightwise is next to nothing. If you're putting a 6' piece on, the weight change is nothing. I've found through the years that if you add weight to a customer's used truck being repaired, they love to see steel on there. They don't care about the extra pounds. It's when the fleet goes to buy the chassis at the dealer that they care about a few extra pounds.”
    Use a straight cut at the splice.
    Body Mounts
    Toner said the purpose of body mounts is to attach the body to the truck frame and prevent the body from moving on the truck frame in a horizontal direction — forward, rearward, and laterally. Rear mounts could be shear plates or some other rigid configuration that prevents movement. Front mounts should be flexible or placed to avoid stress concentrations in high-moment areas.
    He said mounts can be combined to take advantage of the best features of more than one type. Spacer strips used between the body and truck frame perform multiple functions: cushioning member, sacrificial wear member, and stress-spreading member. Rigid mounts should be used at the rear and flexible mounts at the front. The front mount should not be at the front of the body.
    He said if U-bolt body mountings work, use them. But he added a strong caution.
    “I've seen more damage done to truck frames with U-bolts than any other single type of mount,” he said. “A mechanic gets under there and says, ‘That looks loose.’ He puts the air gun on it and torques it until he collapses the frame rail.”
    He said that even though U-bolt body mountings are popular, they are among the least effective mounting systems. If they are used, proper frame spacers must be used. Some of the problems: loosening, not preventing forward movement of the body, and frame damage.
    “Sometimes they don't have the right size U-bolt, so they notch the frame flanges,” he said. “As you can imagine, there aren't many ways you can concentrate stress better than that. If the truck lives its life driving around the city at 30mph never fully loaded, that will probably live.”
    On stress concentration, he said the 6th Power Effect holds that doubling the stress decreases the truck's life by a factor of 64. Therefore, a 300,000-mile truck becomes a 5,000-mile truck. Reducing the stress by 10% doubles the life, and increasing the stress by 10% halves the life.
    “That 10% change is not a lot,” he said. “It really isn't.”
    He said most trucks use ladder-type frames with side rails and crossmembers. Frames are subjected to three types of loads: vertical, torsional, and side.
    Side rails support vertical and side loads such as engine, transmission, fuel tanks, battery boxes, suspensions, bodies, work equipment, and cargo. The crossmembers provide torsional rigidity and support components such as the engine, transmission, and radiator. In addition, the crossmembers prevent the side rails from twisting with side loads such as the fuel tank and battery boxes.
    He said frame strength is described through yield strength, section modulus, and Resisting Bending Moment (RBM). Yield strength defines the material and is the maximum stress, in pounds per square inch, that the material will sustain without permanent distortion. Typical values are 35,000 psi for mild steel, 80,000 for alloy steel, and over 100,000 psi for heat-treated steel. Section modulus defines the shape of the frame material in inches cubed and is related to frame stiffness and flexing. Chassis manufacturer-published section module literature can be as much as 30% too high. RBM is the product of the section modulus and yield strength in inch-pounds, which describes the ability of the frame to carry loads.
    hope this helps
    cam
  18. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Some good info. however the "trucks" in the article are not light duty trucks. There does need to be reinforcement applied to the splice no doubt, the amount of reinforcement depends on how the truck/car will be used. I would only recommend doing a frame splice if you have first hand knowlage. /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif
  19. edlavarreda
    Nov 26, 2002
    56
    thanks a lot guys great info. will post pics when done
  20. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    No, I just saw it on my route.
