crimping electrical connections after soldering
Discussion in 'The Garage' started by bnate, Mar 26, 2006.
  1. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    You know when you get a wire spade terminal from the autoparts store and it is soldered and crimped perfectly......
    How do you get the open ended connectors to crimp down so nice? Is there a tool to do this?
    I always seem to destroy the connector pieces using needle nose pliers. They're all bent every which way and flattened to a pancake. :doah:
    How do they get it so nice and rounded edge so it actually "bites" into the wire to hold it that much better?!!
    Thanks in advance.
  2. 86k5vortec
    86k5vortec Registered Member
    Mar 10, 2006
    14
    switzerland
    there are special crimping tools to make it look all nice. but: never solder before, you should rather solder after crimping, if at all. solder will shrink with time, and if you crimp after soldering, the connection will eventually lose electrical contact.
  3. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, there are several types of crimping tools. Auto parts stores carry them as well as Sears, Lowes etc...
    I just got one to do my own battery/winch cables even. Nice custom lengths!
  5. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    the Kliens rule.. all I'll ever own when it comes to a crimping tool..
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Hey, those are mine!!! Put 'em back when you're done!
  7. bnate
    Mar 6, 2004
    138
    San Jose, CA
    Thanks, guys. Thanks for the added info too.
    What is that, a 4 minute turn around on a question answered?! Sweeeet.
    Love this board! :laugh:
  8. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    The Klein one is good but if you want to move up a step from that, use an AMP crimper for pre-insulated terminals or a Raychem for uninsulated ones. They are not cheap and really should be used with the quality connectors to get the best results. Your crimps will be perfect every time. The problem with the Klein is it only has one size in it.
    There are several styles for the AMP style. here is the only one I could find on e-bay right now
    http://cgi.ebay.com/ebaymotors/AMP-AVIONICS-PRO-CRIMPER-CRIMPS-LUGS-AIRCRAFT-TOOL-AVI_W0QQcmdZViewItemQQcategoryZ26436QQitemZ4625994091QQrdZ1QQsspagenameZWDVW
  9. goldwing2000
    goldwing2000 Guest
    Agreed. I always use a Thomas & Betts. They ain't cheap, though.
    Grainger sells them.
  10. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Those would be a great choice for the truck
