Critique my welds
Discussion in 'The Garage' started by fortcollinsram, May 14, 2004.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Here are some weld I ran tonight. they were all on 3/16" plate.
    Here is a pic with .035" Solid wire and argon/CO2 shielding (75/25) gas
    Now the next two pics are on the same material (3/16") but I switched to .035" flux-cored wire
    and another
    So let me know what you guys think!!! Any tips for improving...
    Also I noticed that with the fluxcored wire, my welds are more prone to having some porosity. What would cause this? Moving too fast? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
    Anyhow, any and all input is appreciated!
    Chris
  2. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    Welds look pretty good. /forums/images/graemlins/weld.gif/forums/images/graemlins/waytogo.gif
    Flux-core IMO is poop by the way.
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I know, I have never been a big flux-core fan, but i have noticed that I get much better penetration when compared to solid .035" wire on my machine (Lincoln sp-135plus) and 75/25 argon/CO2. I may try a tank of CO2 to see if I get better penetration with it.
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    With a smaller machine like the 135, You would probably be alot happier and get better results with .030 solid wire. .035 is a bit big for a 135. Takes more heat to run the bigger wire. A bit less to run the .030. I dunno what the duty cycle on that machine is, but with less heat, it obviously won't heat up as fast, therefore not risk hitting the duty cycle thingy. .030 seems to run a bit smoother. I would bet you had your machine at the upper ends of it's heat range to run .035 on 3/16 plate? .030 would help that a bit. Otherwise, your welds look decent for the first few. Practice makes perfect. /forums/images/graemlins/laugh.gif
  5. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    They look pretty good, I am still trying to perfect the skill too, but compared to KidJethro's my weld's look like I did them with my feet. /forums/images/graemlins/rotfl.gif
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    take and clamp one of those plates in a solid vice and beat the hell out of the other plate with a BFH. Then take a picture. If the plates are still welded together and bent to [darn] the welds are structurally correct as well as pretty. Nice job /forums/images/graemlins/thumb.gif
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    That's too general a statement. Fistly the single shield 'gasless' flux core does do a better job penetration wise. Secondly, with enough practice it can be made to look decent when you're done (although it's tough)
    Lastly, there are many types of flux cored wired out there...and the majority of them make microwire look plain ugly. A dual shield flux cored wire like Lincoln's 71-M with a CO2 shield is an amazing looking weld with exceptional penetration. The thing is I don't think you can easily find a dual shield flux cored wire in a 2 lb spool. Most are the the 30-55 lb spools...
    Anyways, Chris...your welds don't look bad. A little less gun movement and the welds would look smoother. The stacked dimes thing is a bunch of hooey. It's mostly a crutch to keep travel speed consistant. I agree with Joe, .030 microwire would probably run a lot smoother and keep your machine away from the upper limits (allowing longer weld times before the duty cycle limits things)
    Rene
  8. camok10
    May 1, 2004
    288
    Tucson, AZ.
    thats why I said IMO: im my opinion. I personally have not had great times with it. Im sure that there are many people who can make it work great, but not me. However its not like I am an expert welder or anything. If a weld is uglier than my feet, but it holds, then its fine with me. Unless its in a highly visable place, like a bumper. Then i drink some coffee and go use my friends tig. /forums/images/graemlins/woot.gif
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/histerical.gif
    Rene
  10. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Right Awn guys...I am gonna go outside and do the weld-in steering brace today and I will see how it turns out /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
    Chris
