Cross country trip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HD, Apr 26, 2004.
  1. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    We are finally moving back to Kentucky. I have a tow bar for the Blazer and we should have a ’99 2500 Suburban. I was wonder if you guy had any suggestion on flat towing that heavy beast (the Blazer).
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check with tRustyK5. He dragged a K5 behind a K5 from Texas to British Columbia a couple of years back. The biggest problem is going to be stopping with all the extra weight that doesn't have braking power.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    do you still have those 6 lug slotted wheels? I could do a Kentucky trip /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  4. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Remove both driveshafts, at the yokes and secure to chassis. Check differential fluid levels. Disconnect speedo cable, unless you want to record the miles on chassis. /forums/images/graemlins/thumb.gif
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    No need to disconnect speedo if driveshaft is disconnected!
  6. lukebaby1
    Dec 16, 2003
    231
    Richmond, Virginia
    OOPS, Brain Miss! /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/dunno.gif
  7. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    You'll be illegal in most states towing it like that. The max you can tow without trailer brakes is 3000 lbs. The Blazer I flat towed was missing a bunch of parts including the motor, bumpers plus a lot of interior stuff was missing too. Even so mine weighed in at 3400 lbs.
    My 81 Jimmy had no trouble towing it, most of the time I'd forget it was behind me until I checked the mirror. It did surprise me a few times, one time in particular getting onto the I-35 in witchita...the road was wet and the towed Blazer did a nice job pushing the back end of my Jimmy around. That was just enough to illustrate to me that I did need to be a bit more careful. Tight corners can be interesting...backing up is impossible.
    I custom built my tow bar so it bolted up in between the frame rails rather than clamped to a factory bumper. Even so, I'd reccomend renting either a dolly with brakes or a full out car trailer. It'll be a much less stressful drive, and it'll be legal.
    I got nailed as soon as I crossed back into Canada and had to have the Blazer towed by a tow truck the last 12 miles of the trip. /forums/images/graemlins/rolleyes.gif
    Rene
  8. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    How's this:
  9. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    No I sold them last weekend.
  10. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    Rene
    Do you know where I can rent a trailer. U-hauls' trailers are not wide enouth for 12.50's and they say they can only hold 4000lbs. I think that my K5 with the Diesel is about 5000lbs.
  11. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Penske or Budget have trailers big enough. The one from Budget you want is the aluminum full bed trailer. You will have to put smaller tires on it of you want it to sit level. I didn't and come from CA to NC with the Jimmy sitting crooked the whole way but it was safe. /forums/images/graemlins/thinking.gif
  12. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Where in Ky?....
  13. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    A small place called Beverly, in Bell county. It's in the Daniel Boone National Forest, about an hour away from London, KY.
