cross member q?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wally81k5, Mar 9, 2003.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    I'm swapping in a 465/205 and used to have a 350/208. My question is. I have no motor to tell if the tranny is sitting where it should be. Will the cross member with the 465 bolt into the same holes on the frame as my old one? If thats the case it will be fine. But if it's not the case, any one have any measurements for me as to where the crooss member goes? (thats if it doesn't bolt in the same holes as the 350)...
    Thanks.
    Ryan
  2. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    No it won't. What I did is put the motor in, then put the tranny/TC in then slid the crossmemeber in, marked the holes and dilled them with the crossmemeber sitting on the frame. Worked great, and there was no chance of me screwing up the mesaurements.
    nayd
  3. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    So they do have to move... is there any notches or indents in teh frame??
    Does anyone have some measurements they could give me?
    350/465/205... need to know where the cross member goes, as motor is in peices in the garage!
    Ryan
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    thats your best way man.
    even though i have been told my 465/203 combo is the same as my th350/203 combo i am still waiting for the engine to go back in.
    no need to do work twice.
    let alone drill some extra holes in a frame.
    get a bare block, line it all up an install. its easier to do a clutch with the tranny out anyway. so you could be doing it twice anyway.
    Grant
  5. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    I quess eh... if i just strap the block in and slide the tranny up it will be in the same place as if the motor was built.. Maybe i'll do that! Thanks
    Now go reply to my carb q!
    ryan
  6. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    the 465 203 is the same mounting as the 350 203..
    Blake
  7. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Ryan,
    Put mine in last night. The crossmember is forward of where it was for the 400/ 205 by about 2.5-3" . I have to drill mine this am and try to get it finished off. It took us a little longer than I thought to get the trans/ case into the truck, but all I have left now is the crossmember holes, the linkage, and the adjustments. Also, it looks like my rear driveshaft will work... barely. Then I have to remove all the stuff from the auto.. vacuum line, tranny cooler and lines, column shifter and linkage etc. Hopefully I can drive her out this aft. I have to work at 3. /forums/images/graemlins/frown.gif
    Catch ya later
    Mike
