cross member
Discussion in 'The Garage' started by schmuck, Aug 27, 2003.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    does anyone have pictures of thier mid 80s cross member i think mine maybe bolted on wrong
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Which cross member?
  3. schmuck
    Nov 11, 2002
    523
    tranny and transfer case, mine was bolted to the underneath part of the frame when it looks like it should be sitting inside the frame, if it goes inside that would be great because that would give me about 2 inches more of ground clearance right there
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    What year truck?
  5. schmuck
    Nov 11, 2002
    523
    85 with a 700r4/208 setup
  6. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Nope, it is bolted to the bottom of the frame.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, the crossmember does sit under the frame rails, BUT, only the 1 tons had the '85 up to '91 sitting inside the rails.
    1 ton rails are taller and when the crossmember is bolted under the rail, it sits too low.
    Now if you bolt it in the rail, your t-case will sit too high as the t-case may hit the bottom of the cab floor. Also, the shifter may get binded up.
    So, if its NOT 1 ton, bolt it UNDER the rail and call it finished. /forums/images/graemlins/thumb.gif
  8. schmuck
    Nov 11, 2002
    523
    ok thanks, thats not what i wanted to hear but i guess ill have to live with it /forums/images/graemlins/thumb.gif
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it is your truck
    put it where you want
