cross over arm???
Discussion in 'The Garage' started by reeser, Nov 5, 2003.
  1. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Nope!
    You need the Superlift SUP-1104 PITMAN ARM
    For the STEERING ARM on the knuckle I recommend Offroad Designs' D60 High Steer arm. Think ahead brother!
    You can always buy the second one later after you bash your tierod!
  3. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    also...
    Randy Ellis (top fabricator and winner of the second TTC)
    www.randyellisdesign.com
    recommended the ORD arm and crossover setup. The reason: the homework has been done and the angles are taken into consideration (I think it's the Akerman angles). Randy know his /forums/images/graemlins/grin.gifshiznit and so does Steve Watson. Much trial and error has already been dealt with. WHy reinvent the wheel. Fork out the dough and deal with less headaches /forums/images/graemlins/grin.gif
  4. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    i already have the ord arm and junk just no pitman arm, i heard that the stock 2wd arms would work, i'm seriously considering buying the ord arm to complement my other junk. i just need to find one used!
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    do you have a new crossmember? I would think you would need a big bend in the draglink to clear the crossmember without a drop pitman.
  6. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    no new crossmember i'm plannin on grinding it a little if i have to. i don't have this installed yet i'm collecting the pieces first then i'll put this crazy puzzle together. /forums/images/graemlins/thumb.gif
