cross over, cross member and 1 inch blocks
Discussion in 'OffRoad Design' started by four_by_ken, Feb 21, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I was going to do just the plain ole 1 inch blocks... but now I think I will also move the axle forward 1 1/2 inches. Does this cause any problem with cross over steering? Does the move forward of the axle bring it too close to anything in the front of the wheel? What about the rear?
    And anyone have any links to new cross members to help avoid interferance with the steering?
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Moving forward works fine with crossover, 1" movement is really common, 1.5 should be pretty easy. Our draglinks are bent to provide clearance for the crossmember and I do recommend a bit of drop in the draglink to help keep the draglink end angles flat. If not the MOO crossmember on the main page would work.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
