Cross-over: Is 3" drop Pitman arm a problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian 89KBlazer, Apr 25, 2001.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I can get a BDS Pitman arm cheaper than Superlift arm (same application as Superlift 1104) but it's got a 3" drop instead of a 2". Anyone forsee any problems using this with the Rockrod in cross-over steering?
    Brian
    89KBlazer
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Re: Cross-over: Is 3\" drop Pitman arm a problem?
    I used the pitman arm froma 1978 3/4 Ford van. It fits the 2wd chevy steering box without modification and has the right amount of drop to clear the frame. Get em your local junk yard.
    <A target="_blank" HREF=http://65.11.18.114/_private/crossover1.htm>http://65.11.18.114/_private/crossover1.htm</A>
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
