cross over, new cross member, and 1 inch blocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Feb 21, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    Allenton, MI
    I was going to do just the plain ole 1 inch blocks... but now I think I will also move the axle forward 1 1/2 inches. Does this cause any problem with cross over steering? Does the move forward of the axle bring it too close to anything in the front of the wheel? What about the rear?
    And anyone have any links to new cross members to help avoid interferance with the steering?
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  2. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    Stillwater, Oklahoma
    Re: cross over, new cross member, and 1 1/2 inch blocks
    Steve said it shouldn't affect anything on the crossover steering if you keep the axle moving "within reason." I'd say 1.5" is within reason. I'm not sure about the other questions.
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps <a target="_blank" href=http://members.aol.com/fileholder2meg/projblazer.html>Clicky</a>
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    Bay City, MI 48706
    I asked Watson the same question over on the ORD forum. He said it won't effect the cross-over steering by moving it only 1.5". By moving the axle forward a little you will be moving it away from the back fender well. This is where most of the guys had to trim or bash it in with a hammer, to fit the big tires in there. Since the tires move towards the back when the front suspension flexes it would be ideal to move it forward a little to lessen the chances of the tires rubbing.
    I plan on running the zero rates on both axles. Especially when using the flip in the rear. I would like the tires to have as much freedom of movement in the wheel wheels when my suspension starts to flex.
    74 Blazer
    Check out my Blazer
    <a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
