Cross over pitman arm Idea
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Oct 25, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I was just wondering why no one makes a pitman arm that will fit on a 4wd steering box. I'm pretty sure some people would rather go that route rather than changing the box. Any negatives to something along that lines? Also anyone know the length from axis to axis of the pitman arm ORD uses for the cross over kit? I need to know how long to make the arm I am bolting on top of my king pin.
    Thanks all,
    Mike
    The jeep eater ......jeep it's what's for dinner[​IMG]
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i thougt of that too but its bcuz of how its cl;amps to the shaft , it would have to be 90deg and i dont think it would be very strong , but i am not sure , ill check mine out , er wait i have ords 1/2 ton axles...plus the arm unless dropped , would fit under the frame
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)<P ID="edit"><FONT class="small">Edited by K10ANDYKHAMNIC on 10/24/01 11:50 PM.</FONT></P>
  3. mpascino
    Jan 1, 2001
    557
    Connecticut
    What I had in mind was I complete pitman arm that would bolt in place of the stock one , that could be indexed in the correct direction. Just a thought.
    Mike
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I was thinking the same thing this past week and a half when I was doing the lift and axle swap. There must be a reason for it not being done otherwize you would think somebody would be selling them.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    The reason is the direction that the steering box turns, not the type of pitman arm.
    Ken H.
    '85 K5 in process
  6. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Hey Ken,
    Wouldn't the rotation be the same? I mean if the pitman arm is turning front to back in the stock location it seems to me that if you were able to pull the pitman arm straight down and rotate it so that it was pointing towards the back of the truck and then put it back on it would now be rotating from side to side. I could be wrong (it's happend before [​IMG]). They say all you need to do is take the shaft out of the box and then replace it with a 2 wheel drive shaft and you are done. I believe the reason is the splines on the 2 wheel drive shaft make it so the pitman arm can be rotated completely around the shaft. You can't do that with the 4 wheel drive shaft and pitman arm. Just my $.02
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    You know, someone told me this a few years ago and I ahve not done cross over on the Chevy yet(only Jeeps). And I have never really thought about if he was full of it or not. I am going to have to look at it a little more. But, it sounds like you are right. Since I plan on finishing mine within the next couple months, I better figure it out quick. Thanks for gettting me thinking on it.
    Ken H.
    '85 K5 in process
  8. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    The stearing shaft on a 4wd box is only indexed in one place. This means that the pitman arm can only be placed in one position. This position allows for front to back movement of the pitman arm. The 2wd box is indexed in four positions. That means you can rotate the pitman arm on the shaft in 90% increments. This will allow for the side to side movement of the pitman arm that crossover steering requires.
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You should post this on the ORD forum.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  10. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Yeah, the rotation is the same for two and four wheel drive steering boxes on a chevy.
    As for why no one makes a cross over pitman arm to fit the stock box...I have no idea. I never really thought about it cause my box was shot and I needed a new one anyway.
    A computer once beat me at chess, but it was no match for me at kick boxing.
    <a target="_blank" href=http://photos.yahoo.com/dana60manual>http://photos.yahoo.com/dana60manual</a>
  11. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I have read that there is a pitman arm for a 4wd box that you can buy that positions the pitman like a 2wd box/crossover setup. I think I remember people saying something about "Mike the parts guy" Anybody else have a # or contact?
  12. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    I just made my steering arm for my crossover. It was ~9 3/8" from king pin to drag link rod eye end. My setup was as follows.
    Dana 60 1" further forward
    AGR 2wd Rock Ram Steering box
    1977-79' Ford F150 drop steering arm
    76-82 Chevy Pickup / Blazer - K5-K10-K30
    90' TBI
    TH 400
    203 / 205 Doubler
    Dana 60, Corp 14 - 4.88'd - Detroit Locked
  13. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the reason no one makes one is the $$$
    when a 2wdr box is so cheap and the volume of the sales of a cross over pitman would be so low, it doesnt make economic sense.
    that's my guess
  14. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    If the spline patterns are the same for both shafts, you could file out the indexes on the 2wd arm so they clear the splines on the shaft. I'm not sure if they use the same spline pattern though.
    Joe
    RIT Mini-Baja www.rit.edu/~bajawww
    Team Mudnuts www.mudnuts.org
  15. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    The 4wd drive box doesn't have splines. The pitman arm clamps on to the box.
    Chad
  16. californiak5
    Oct 25, 2000
    820
    It does on the opposite side of where the bolt notch is on the shaft.
    Keith
