cross over steering idea?
Discussion in 'The Garage' started by gotmud77, Jun 21, 2005.
  1. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    Is there any reason you cant take the knuckle off the drivers side and swap it to the passenger side? You would cut off the tie rod mount and use the 3 studs for your arm. You would just need to stack the tie rods. It looks like it will match up. This would be on a dana 44.
  2. clancy84
    clancy84 Registered Member
    Feb 8, 2004
    41
    san jose area, CA
    Caster,camber and steering axis inclination are all determined in the end of the axle tube i belive, so that would all swap over fine. the only problem would be with the ackerman,but since your talking about using a bolt on arm on top you can deal with the offset required there. you also have the little axle stop that keepts the joint from over extending, you would need to figure out something there. sounds like it could work...
    --Scott
