cross over steering pitman arm Q
Discussion in 'OffRoad Design' started by bigwishlist, Feb 17, 2003.
  1. bigwishlist
    bigwishlist Registered Member
    Apr 14, 2002
    47
    Sheboygan Falls
    When switching to X over steering do I need to switchout boxes from 4wd to 2wd? Or do I just need to switch pitman arms from front to back to side to side. If so where can I get one? Thanks.
  2. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    you need a 2wd steering box and a ford dropped pitman arm.
    -Scott
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You need either a 2wd steering box OR swap the sector shaft from the 2wd box into your 4wd box.
    You will need the Superlift #1104 pitman arm. About $50.
    -- Mike
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ok man, for the fourth time! Your steering box is fine for crossover. You dont' need a new one! All you need to do is order a pitman arm from ORD!!! You have an IFS truck and the box that comes in them are correct for crossover!!!
  5. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Are you doing this to the 94 or the 74??? /forums/images/graemlins/confused.gif
  6. bigwishlist
    Apr 14, 2002
    47
    Sheboygan Falls
    Its for my 94 and I understand the parts I need to do the switch. Thanks to all.
