cross over steering problems?
Discussion in 'OffRoad Design' started by four_by_ken, Jun 16, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    The axle I am going to use in my Blazer is currently under a Jeep. I did a cross over steering setup on it. I do not have any interfearance with a straight drag link from the pitman arm to the sterring arm on the knuckle. Will I have to worry any about the drag link hitting the spring or the cross member when I bring this over to the Blazer. I know I will need a longer drag link, but anything else I should know.
    Also, I have been considering bringing the tie rod up top also. Any comments on this? Biggest problem I see, is that I will loose the steering stabalizer mounting point. Which I really do need. Unless I can solve this problem, I will just leave the tie rod below the springs.
    Ken H.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Dumb question: How do you relocated the tie rod higher?
    -- Mike
  3. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    By using flat top knuckles and a steering arm mounted on the top. That makes it able to run the drag link and the tie rod above the springs, out of harms way. They both run over the springs.
    Ken H.
  4. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    With cross over steering on a Blazer, the drag link will hit the crossmember under the engine. But there are things you can do to avoid this. One is to have a custom cross member made.
    http://www.rockstomper.com/
    <A target="_blank" HREF=http://www.rockstomper.com/catalog/steering/rockrods/rockrod.htm>http://www.rockstomper.com/catalog/steering/rockrods/rockrod.htm</A>
    I went with the dropped drag link, since it is a hundred bucks plus shipping and I don't weld (yet) so it would be about a hundred bucks to make the crossmember and I still would have had to get a drag link somewhere.
    That's because I'm the devil.
  5. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    How much drag link strength is lost when bending it? It seems to me that force on it would bend it more. Maybe I'm wrong. That is definitely the easiest way to do it.
    Chad
  6. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Chad, bending a stock tie-rod to use as a drag link would indeed be weak.
    The rockstomper is another story altogether. It is so much stronger that even with the bend, it is overkill strong. Check out the website and you'll see.
    -- Mike
  7. ChadH82
    May 9, 2001
    400
    Ok, Thanx!
    Chad
  8. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    Yes, as TX Mudder said, these things are over kill strong. I'm just getting ready to paint mine. Here's some picks.
    <A target="_blank" HREF=http://y42.photos.yahoo.com/bc/maxcrack/lst?.dir=/Truck+Stuff/Tie+Rods&.src=ph&.order=&.view=t&.done=http://y42.photos.yahoo.com/bc/maxcrack/lst?.dir=/Truck+Stuff&.src=ph&.view=t>http://y42.photos.yahoo.com/bc/maxcrack/lst?.dir=/Truck+Stuff/Tie+Rods&.src=ph&.order=&.view=t&.done=http://y42.photos.yahoo.com/bc/maxcrack/lst?.dir=/Truck+Stuff&.src=ph&.view=t</A>
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'm still a little leery of big bends in the draglink because I had a slight bend (1 1/8" offset) in my draglink on the 10 bolt setup and it hit the leafspring on the right side when it twisted. It had a thick leaf pack, but it's still a concern. But it may work with more "out of the box" springs.
    I would beware of moving the tie rod up, it's nice to have it out of the way, but running the draglink into the tie rod causes it's own set of problems. The tire rod rolls over with steering input, it shortens the draglink, and there are also clearance concerns again. I had to run my draglink into my tie rod, but did so grudgingly. Biggest reason was to minimize angle change on the end. All my ends rotate, there's very little angularity on them now.
    Making the world better, one truck at a time.
    [image]http://coloradok5.com/logo_ordsmall.gif[/image]
    SW-ORD
